Question about Dometic RM2852 Refrigerator
Royale frig in 1996 gulfstream rv does not work. the inside frig lite comes on, the outside a/c lite comes on the gas lite does not come on. the is rust on the back side of the frig. the freezer floor gets cool to the touch
  • maratara Jun 02, 2010
    no odors, no yellow stuff. neither frig or freezer work.the lite in the frig comes on. the outside a/c lite comes on, the gas lite does NOT come on and freezer and frig do not work.
  • maratara Jun 03, 2010
    is the board bad pr the whole frig?
  • 2,272 Answers
The power board is faulty and that needs to be replaced.The whole fridge is not faulty its the fault of board.But before replacing the board check this
Have you checked there is enough gas in the unit ? Yes - continue
Have you checked that the gas bottle is turned on? Yes - continue
Have you checked whether there is an internal gas **** that feeds the refrigerator? Typically the gas **** is in a cupboard near the refrigerator.
Is the igniter sparking? If no it needs to be checked and replaced.If  Yes - continue
There may be a blockage in the gas lines or a sensor is malfunctioning in which case it may need factory repairs or replacement.
But if all the possibilities checked out OK then the board needs replacement.
For getting parts for your fridge you can get it from the above link
http://www.gasrefrigeration.net/parts.htm
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 03, 2010
  • 857 Answers
you may have a bad board, but we can check a few things first.... first off, on the back of the fridge, should see the control board, remove the black cover from it and towards the right of the board, should have 2 fuses, often covered in a blue plastic sleeve or something.. check both these fuses are good.. if they check out you are going to need a test light.. if you dont have one, can get one from auto part store cheap... need to first see if getting voltage to the gas valve and if the gas valve is even opening.... does yours have the 12v element option? can tell by looking at the back, on the right hand side where the burner is.. above that, should see the 110 element.. if there are 2 elements, then you have a 12v element too.... let me know if you have the 12v element option... also, check the fuses.. then check for power to the gas valve... byusing a test light, turning it onto gas and seeing it it gets power.. it will only have power for a short while as it tries to light, then will shut down.. so may want someone inside to turn it on for you..... also try unplugging the electrode wire from the board and then plugging it back up.... sometimes these can get a little dirty... since you have no spark at all... you can try using a screw driver and holding it over the connectore on the board for the electrode wire, see if it sparks to that.. however, make sure you have a good plastic handle and wear gloves, else it will knock your socks off if it gets you...
Posted on Jun 02, 2010
  • 1 more comment
    the gas valve turns on for 3-4 seconds then clicks off.
    we do not have the 12 volt element
    checked out all of your suggestions, all checked out. we do not have 12 volt element
    Genius:
  • 1,040 Answers
    the frig does not work on gas or electricty.
    there is no smell, no yellow discharge, nothing the naked eye can see from the outside.It does not work on gas or a/c.the doors shut properly, its clean. what can I check now?
Where can I get an owner's manual for a 2007 c class 30' gulfstream ultra se?
Gulfstream is not manufacturing motor homes any more, only travel trailers and fifth wheelers. You can download a copy of a 2010 generic RV owners manual for Gulfstream RVs at the link provided. http://www.gulfstreamcoach.com/towablelanding/2010editionmotorhome.pdf
Oct 22, 2016 | Cars & Trucks
Where can I find a 1989 Gulfstream Classic Motorhome RV manual
Try rvrepairmanual.com they may have what you need there is a number that you can contact them if your having a hard time with the web site
Feb 03, 2015 | Rv Motorhome Dual Co & Lp Gas Alarm...
On my 2010 trailmaster 269bhs the hotwater doesnt work can i switch is to straight gas instead of electric
You can switch it out but pretty labor intensive. You cannot just add a gas option to the unit. You will have to replace it with a gas heater and then plumb it to the tanks. The existing unit probably has something simple like a safety sensor that went bad or a heating coil.
Aug 26, 2013 | Gulf Stream RVs
Need free owners manual for a 2002 Gulfstream Classic RV
http://gulfstreamrvtrailers.com/contact-gulfstream.php
Aug 01, 2013 | Water Heaters
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Royale rv fridge lights on gas then goes out
clean burner assembly with compesseed air if no fix replace electrode the spark thingy as most women say to me lol 33.50 most dealers
Jun 08, 2009 | Dometic RM2852 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Dometic RM2852 Refrigerator Logo
66 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
