Question about LG Dehumidifiers
MY DEHUMIDIFIER IS GETTING VERY HOT - DANGEROUS?
  • 1,284 Answers
Hi, sure it's normal. A dehumidifier works alot like an air-conditioner. Since warm air holds more moisture than cold air, it cools the air to remove the moisture. The heat energy that has been removed from the air has to be exhausted (as well as the heat it takes to run the machine itself).
Take care
Posted on Jun 02, 2010
  • pfburns Jun 02, 2010
    YES, BUT IT'S REALLY HOT!!!!!!!
  • Shehu Pro
    Shehu Pro Jun 02, 2010
    Whao! It sounds as if the unit has lost it's refrigerant charge. Take to
    small appliance repair for confirmation, but it probably leaked out.
Fridigaire dehumidifier compressor gets very hot and no water in bucket
Good Morning Friend,
I understand that the compressor is getting very hot and there is no water in the bucket of your Frigidaire dehumidifier, model# LAD704TDL. I would check to make sure that your dehumidifier has enough ventilation. There should be a minimum of 12 inches clearance around your dehumidifier. Also, make sure that it is neither too hot, nor too cold where you have placed your dehumidifier. Your appliance is designed to operate between 41 degrees Fahrenheit and 96 degrees Fahrenheit. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dehumidifier status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Dehumidifier LAD704TDL
Dehumidifier repair
If nothing at all works, its most likely a control (switch or stat). Be very careful if you try jumping them. Line voltage is dangerous if your not sure of what your doing.
Oct 15, 2013 | Dehumidifiers
Motor is making very loud noise when on and bucket is not filling up with water. Machine is getting very very hot at the top when turning on.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Sep 02, 2011 | Amcor AHD65 Dehumidifier
Unit will do a small of amount of dehumidifing however the unit gets very hot on top and blows very hot air out of rear. Could this be a lack of freon or whatever is used and comprssor getting hot??? ...
heatman101
May 25, 2011 | LG Dehumidifiers
From Day 1 this dehumidifier, after running for a couple of minutes it gives off a very loud buzzing sound - not at all the typical motor sound. What is this and how do I fix it? Is it...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It is not dangerous, but it also is not working...the sound is the compressor trying to start and not getting started... so the machine is basically toast... would cost more to fix then it is worth...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 14, 2010 | LG LHD659EBL Dehumidifier
I have an Aprilaire 1750 installed inline with my upstairs central air system in the attic. The unit's ducting appears to be installed as indicated in the installation manual, but when the unit is running...
Your dehumidifier is likely working correctly. When operating and removing moisture, a dehumidifier will supply warm/hot air to your house. Your dehumidifier moves less air than your A/C, so your supply ductwork in your house is oversized for the dehumidifier. This will lead to uneven feeding of your supply duct branches with just the dehumidifier operating.
Since your dehumidifier is installed in the attic, make sure that the ducting connected to it is well insulated. Also make sure that your dehumidifier cabinet is insulated. These actions will help prevent heat gain from the hot air in your attic.
Is your dehumidifier bringing in fresh air from outside? If the outside air is hot and humid, the dehumidifier will supply warmer air to your home.
Some people run their A/C fans continuously to help with the air distribution, but this is a bad idea since it increases energy usage considerably.
DryDog
Aug 06, 2010 | Aprilaire 1700 Dehumidifier
Dehumidifier
Again, if your model is one that can be used in cooler temps so as not to ice up, the heat prevents this.
Aug 07, 2008 | Maytag M7DH45B2A Dehumidifier
Dehumidifiers Logo
90 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
