Question about Asko Washing Machines
My asko frontloader won't fully drain and I cannot get the whit plastic cap off the drain to see if the hoses or filter is clogged. The top piece pulls off but not the underlying piece. any ideas? Isn't this where I open it to unclog?
    Sergeant:
  • 351 Answers
Yes you need to get the filter out it will be full of coins etc.you will have to break it to get it out.you can get a replacement pintrap from asko
Posted on Jun 16, 2010
Asko 620 washer won't drain well with heavy load
Washing machine won't drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump:
Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Asko W6021 Front Load Washer
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
My washer w6221 won't drain
Check this following things then your washer will be fine.
* Has the drain hose been put flat on the floor?
* Is the drain hose clogged with lint?
* Is the drain hose kinked?
* Is any part of the drain hose higher than 20 cms from the floor level?
* Is the extension drain hose longer than 3 m?
* Is a narrow drain hose being used?
Thanks for your question.
Jun 26, 2011 | Asko W6221 Front Load Washer
Samsung frontload washer fashing nd code
The ND code means not draining
The older versions of this machine did not have a debre filter, but in later versions a drebe filter was added . It is on the bottom right of the front panel. Open the door. Pull the cap off the drain hose and drain water into pan. Remove filter cap. Wash filter off and don't block propeller when replacing filter cap. Insert cap back in drain tube.
Jun 04, 2011 | Samsung WF328AAW Front Load Washer
GE dishwasher GSD2230 won't drain completely after it completes entire cycle.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
May 18, 2011 | GE 24 in. GSD2230Z Built-in Dishwasher
Dishwasher won't drain
Hi
Daniel
May 07, 2011 | Dishwashers
My dishwasher is filled with water and won't drain
Hi
Daniel
May 07, 2011 | KitchenAid 24 in. KUDS02FRSS Stainless...
Won,t drian the water.
Hi
Feb 21, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
1" of water standing in bottom of dishwasher after cycle? what is the problem
Hi
Oct 20, 2010 | Asko 1375 Dishwasher
Bosch dishwasher SHU4000 problem starting, not draining
Drain problems are almost always going to be a clog. Disconnect the drain hose from the air gap vent at the sink top. Place a bucket under the hose and run the drain cycle. Unit should drain. If not, clog is either in drain hose or under the dishwasher's internal filter. Remove filter. Locate the item causing the clog and remove it. If nothing is found here, the problem will be in the air vent gap filter itself. Disconnect the other hose and remove the air vent gap from the sink. There's a small cap at the top of the filter. Press the clips in to remove the cap. Flush the unit with water or use a thin, long blade screwdriver to remove the debris.
Put it all back together and test again. You should be fine.
Mar 20, 2010 | Bosch SHU4006 Dishwasher
Washing Machines Logo
85 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
marley mcelhinney
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
