Question about Canon ImageClass D880 Copier
Paper jam on a Cannon D760 copier
The paper is in an area that is not accessable (fuser area). I've taken a few pieces of plastic off, but before I go any further I need some help or pictures of the parts to remove to get at the paper???
    Problem Solver:
  • 5 Answers
A technician who knows what he is doing is required to access the Canon fuser.
However, If you remove the glass on some later models there is an access hole wear you can get a long shank screwdriver down to the screw that holds the fuser in place. On some older models I have actually drilled a hole through the optics area to access the screw. You can get it with a stubby, but it is not fun. Getting the covers off is like working a rubics cube, good luck...
Posted on Aug 13, 2010
My cannon D760 quit working. It flashes E000
if you are able to repair it.then look for paper jam in the fuser unit.E000 is related to fuser section
Jan 15, 2011 | Canon imageCLASS D761 Copier
I had a paper jam and was able to get paper out but whenever I print something there is a thick line that does not copy down the middle of the paper and a crinkle sound like paper is stuck inside the...
Bad news, the "golden'" paper is actually a piece of the fuser film of the printer. Out of experience i have found that a new fuser film costs almost as much a a new printer.
Found this link that may be usefull in making a decision whether to replace the fuser or buy a new Printer :)
http://www.precisionroller.com/fuser-assemblies---units-for-canon-imageclass-d760/products.html
Sorry for the bad news
BD
Sep 07, 2010 | Canon imageCLASS D760 All-In-One Laser...
I have d760 cannon copier. finally removed the
hi,
Check to see if there is paper in the fuser unit, it does consertina in it. I wood use a torch because these are difficult to see without a torch. Take the left covers off to see better.
Good luck
Oct 20, 2009 | Canon imageCLASS D760 All-In-One Laser...
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Paper folds and jams before
your description points to a fuser assembly problem which is right where you looked. I'm not sure what that plastic piece is from. if it is black, it probably came from the fuser. That is a replaceable part, but I'm not sure you can still purchase them from Xerox.
Jun 24, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Won't print - says 'paper jam 2' but no paper is stuck in machine
Paper jam 2 error code is saying the jam is in the fuser area of the machine.
You need to remove the toner cartridge, and since you said you've taken the whole thing apart, maybe try a flashlight and look for a LITTLE piece of paper that may have torn off that remains stuck around that fuser area (the fuser is the thing behind the toner that gets hot-- so be careful -- but look in the corners and anywhere a small piece of paper could have torn and got stuck.
If you're absolutely sure that there is nothing stuck, I'd try to do a hard-reset: Turn off the machine, unplug the power cord and the cable that goes to your computer (if it's hooked up to one. And if it is hooked up to a computer, power down the computer as well.) Wait a minute or two, plug the computer back in, plug the power cord and cable from the printer back in, then turn on the printer and the computer and let them both go through their various start-ups.
If none of that works, let us know.. but from what I know and the docs I have access to, it should work... (fingers crossed!)
Good Luck!
Maggie B
Feb 22, 2008 | Samsung SCX-4216F All-In-One Laser Printer
My cannon super 63 image runner 1370f
look on the control panel if there is a diagram of your printer it will usually light up the area where the paper jam is located.
once you find location of paper jam there is normally a green knob in the area of jam that when you manually rotate it will release paper also open paper drawer check for jam or unplug and plug copier back in somtimes this will force paper out as it resets
Jan 13, 2008 | Canon IMAGERUNNER 6570 Copier
CANNON SUPER 63 IMAGE RUNNER 1370F PAPER JAM
It is hard to tell where the paper is with out seeing it or looking at the jam log. start by looking for green. On canon green is for jam removel if you see a green tab lift it, if you see a green knob turn it. good luck
Jan 12, 2008 | Canon IMAGERUNNER 6570 Copier
Cleaning a Canon d760
I am not sure of that ,the best way to clean it is to do it manually by having the machine being serviced by an expert .
Dec 12, 2007 | Canon imageCLASS D760 All-In-One Laser...
Paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Jun 14, 2007 | Canon imageCLASS D760 All-In-One Laser...
Canon ImageClass D880 Copier Logo
166 people viewed this question
old marine
old marine
