Question about InFocus LP640 Multimedia Projector
InFocus projector display has a blue color and yellow lines/blotches. Is this worth repairing?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 269 Answers
If these blemishes look like maybe its fuzz or something, you can remove the top cover and use compressed or canned air to blow out the area where you see 3 orange flat cables going under the main board into the lcd panels. blow it out good and be careful not to disconnect the cables as that can be a pain for the inexperienced. If this doesn't fix your problem, then I would say that the lcd panels have been burnt due to shutting the projector down improperly numerous times and no it is not worth repairing unless you get a known good light engine for less than the cost of a new projector plus labor-- unless you DYS.
Posted on Jun 11, 2010
I have a large yellow blotch in the middle of the screen that will not go away. What do I do?
Sorry, your lcd on the Blue has burned, spare parts mean replacing the main optic combiner and lcd module that is more expensive than the projector is worth. it is dead, I have several similarly dead units.
Aug 17, 2011 | Hitachi CP-X1250 Multimedia Projector
Hi there, my dell projector 1800mp is not projecting an image on screen and it only black lines across. what should I do to fix it?.
After turning on the projector, press "+" and "-" buttons on the control panel
simultaneously for 3 seconds and release the buttons when screen goes blank.
2 Press "+" and "-" buttons again to exit the diagnostic mode.
3While in Self-diagnostic mode, the screen will run a seven-color-cycle test as
following:
Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow.
Ensure that the colors of the test pattern are correct. Contact Dell if the colors are
not displayed correctly.
Mar 02, 2011 | InFocus LP 250 Multimedia Projector
Infocus DP8400x blue hazey line
this discoloration is the begining of the lcd panel being thermal damaged. this happens when the projector is being used for a long period of time and then being shut off using the switch on the rear of the projector instead of the on/off on top or the remote. to fix it it will have to be replaced. very expensive major repair.
Jul 11, 2010 | InFocus DP8400X LCD Projector
Yellow green display
you may have a bad cable. if it was an internal problem, the menu wouldn't be the correct color. you may also want to reset the settings to factory default, just to cover the resolution issue.
Jan 13, 2010 | InFocus LP70+ Multimedia Projector
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
Not displaying full colors
I had a bad M1 to VGA cable. The blue video channel in the cable was broken.
Apr 22, 2009 | InFocus LP70+ Multimedia Projector
No color
Color wheel disc is broken and not repairable, problem is unless you know someone that can get the part you have to take your projector to an authorised service centre.
Dec 11, 2007 | InFocus ScreenPlay 4805 Multimedia...
Color wheel for a 4805
I've encountered this same issue. I had a large Yellow Line down the left side of the screen for a few months. It got bigger and bigger, then one day I was using it and Bam! What sounded like a fire cracker was my color wheel exploding. I also had the rubbing sound, or at least something similar to that sound prior to the explosion. InFocus quoted me about $300 to fix..
Nov 07, 2007 | InFocus ScreenPlay 4805 Multimedia...
Yellow area in the projected image
Hello Media Man,
Looks like your projector has done it. Thats acommon trouble to ageing polirising lens, usually the blue. less blue, the green and red make up the yellowish image on the screen. The blue is bombarded with tremendous heat from the lamp and it fade and wash out. If its free, its worth replacing. Get quote for the poliriser; 2 pieces each color.
Good Luck.
Sep 28, 2007 | Mitsubishi ColorView XL30U Multimedia...
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
InFocus LP640 Multimedia Projector Logo
451 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
