Question about Sony STR-DH500 A/V Receiver
My STR-DH500 keeps powering off and clicking rapidly.
My STR-DH500 Multi-Channel AV Receiver keeps powering off, either immediately, or after 20 minutes, and clicking rapidly as if it's struggling to power back on.
    President:
  • Sony Master
  • 1,114 Answers
The most common problem found on FixYa for Audio VideoMy STR-DH500 keeps powering off and clicking rapid - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
Multi channel av receiver str dh700
un plug ac power. then disconnect all the speakers. plug in ac power and turn on. Still in protect? Could be blown amplifier.
Not in protect? one or more of the speakers or speaker wire is shorted
Aug 25, 2013 | Sony Audio Players & Recorders
No sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
Sony strdh500 will not recognize sony ps3
your hdmi port doesnt carry audio to all speakers what is perfectly normal for low end receiver, hdmi pass through audio only
Nov 30, 2009 | Sony STR-DH500 A/V Receiver
Can i use a turntable with the sony str dh500 model? I am illiterate when it comes to hooking this stuff up. Planning to purchase this model only if I can hook up my record player as well as my cd player.
This particular unit only has 2 line level inputs for audio devices. You can use 1 for the CD player and the other for the Turntable. Please note that you will need a phono pre-amp for the turntable as the inputs on the receiver are line level. The preamp will amplify the phono level to line level.
Dan
Nov 17, 2009 | Sony STR-DH500 A/V Receiver
Goes into protect mode..
you probly have speaker wires arching. unplug them and replug thm in making sure no bare wire is showing
May 17, 2009 | Sony STR-DG520 Receiver
Sony STR-DH500 A/V Receiver Logo
968 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
