Question about Mitsubishi MS15TN Air Conditioner
My Mr SLim Model MS12TN indoor unit is leaking, I cleared the outside hose, I have cleaned filters, run dy mode, what causes this. I pourchased unit in May 2005
    New Friend:
  • 9 Answers
Well this units have sort of a goo like foam tape that holds the coil in place it sounds to me that part of that is allready damage and the water is running down the coil and out of the drain pan the only way to fix it is to replace that foam tape.
Posted on Jun 03, 2010
Icing up outside. no heat inside
Isolate unit to defrost out door unit,
Once defrosted run unit ensuring heat from unit inside and fans are running outside,
if fans and compressor are running and there is next to no heat inside coming from indoor unit this is a common sign of a refrigerant shortage in system and this may cause outdoor unit to freeze up
Jan 24, 2016 | Mitsubishi Electric Mr Slim E12C26426...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Mr slim ticking noise
Open it and take a look, it could be debris or a loose wire.
Dec 06, 2013 | Mitsubishi Heating & Cooling
Water dripping out of Mr. Slim on indoor unit.
Reason for water leaking.
1. Filter block. 2. Cooling coil block. 3. Alignment of indoor a/c unit is sloping downwards. 4. Drain pan block. It's advisable to service your unit first.
Jul 02, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
There is water coming out of my indoor unit. So much water that I had to shut off the ac unit. It is a Mitsubishi Mr Slim split type air conditioner/heating unit
water coming out of an a/c is normal .its water outlet hose is wrongly installed or not installed at all.get it installed.also level the indoor unit towards the water outlet side when u install the hose .
Aug 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Water spitting at indoor unit
pull the filters and clean them see if you can see any ice on the coil in side. blow in to drain line out side to clear the line.
Jun 05, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr. Slim MXZ30TN Air Conditioner: Indoor unit blinks on and off what is the problem?...
continuous flash is frost prevention ...clean the filter & switch fan to high
flashes once every 2 sec could be room air sensor contact loose/short...call dealer
flashes 2x every 2 sec is indoor coil sensor contact loose/short...call dealer
flashes 3x / 2sec sensor contact problem, or compressor overload protection trip or gas leak...call dealer
May 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
No heat generated from the inside unit in Misubishi Mr. Slim
If you do not have a windbaffle installed on the outside unit the unit may never come out of defrost in low ambient temperatures. Depending on the outside temperature it might be telling the pcb to stay in defrost to keep the compressor from slugging and being damaged.
Jan 20, 2010 | Heating & Cooling
I have a Mitsubishi Mr Slim model MSZ12UN. The
you must see the indoor fan and you must clean it very good as well all the indoor unit.
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MS15TN Air Conditioner Logo
267 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
