Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
WATER LEAKS INTO INSIDEBOTTOM AND VEGETABLE CONTAINERS
    Novelist:
  • 77 Answers
You have a top mount refrigerator and this is a normal problem. What you have is a clogged up freezer drain, and instead of water going down the drain it goes down the air vents into the frig! Here is what you do.
The drain is behind the freezer wall. Unplug the refrigerator first. Then you need to empty out all the food in the freezer. The screws holding the back wall in are generally 1/4 inch nut driver and phillips head screws. Take out the screws and the ice maker if you need to.
The drain is in the back on the bottom, and probably under a bunch of frozen ice. Just be careful not to damage the freezer, but chip away with a flat blade screwdriver, or just use the hairdryer on it all. You will need to soak up the water with a tower, there will probably be a lot. Next, you need to thaw out the drain, this can be somewhat difficult. Simply blowing hot air doesn't do much good, because it's a small hole. I take some 1/4 inch plastic water line and **** the water out. Then I pour HOT water (from the microwave) down the drain. I let it sit a bit and then I **** it out and reapply.
This process should get it clean. Also, once it's free, I take the 1/4 inch plastic water line and stuff it down the vent a LONG way and make sure any obstruction is removed. Now just put it back together!
Posted on Jun 02, 2010
Testimonial: "YOU GUYS ARE AWESOME. YOUR FIX FOR MY REFER WORKED GREAT. THANK YOU ROBERT IN FRESNO CA. E "
Build Up of Ice in Refrigerator
Maybe coming from the water filter. How old is the filter?
Jun 29, 2016 | Refrigerators
Steady coolant leak but reservr stays full 03 buick rendevous
steady coolant leak could be coming from radiator hose at thermostat or water pump.check water pump weep hole and gasket for leak.check heater core hose leaks or look for leak at the radiator side containers.
Dec 28, 2012 | Cars & Trucks
My whirlpool refrigerator Model ET18PKX6W00 leaks water under vegetable bins
Check behind the bins for a condensation tray/hose. Most refrigerators have these as they develop condensation due to the temperature differences when opening and closing the door. The tray catches the condensation, and drains it to a tray under the fridge. Here it evaporates when the compressor runs. Sometimes things block the tray or the hose gets clogged with gunk. clean out the tray/hose and hopefully your problem will end.
Dec 30, 2011 | Whirlpool Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
My freezer seems to be accumulating water under the drawer. it is coming from the back wall on the right, but there is no leak anywhere else. I do not have an automatic icemaker installed. What could be...
Plastic water bottles on upper shelves sometimes have small leaks. Remove all above water containers. Maybe you spill some water replacing ice trays? Identify the source of water..that will be the cause of problem.
Feb 16, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
My refrigerator leaks water on one side & the water collects in one of the vegetable coolers. I am now unable to use that vegetable cooler & am having to constantly wipe up. The seals appear to be...
I have Model ET8CHMXKQO-3 whirlpool fridge with the same problem. The problem I believe is due to the drain line to the tray that collects defrost water freezing up. Temporary solution is defrosting the fridge; permanent solution is running a thin wire thru the drain line that aparently prevents the condensing water from freezing. I am trying to find out how to install this wire and where to buy it.
Jan 28, 2010 | Whirlpool Refrigerators
Maytag Wide by Side leaks from the refrigerator side
Hold the door switch in and you should be able to watch it leak.
Sep 10, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Cleaning solution leaks
It could be the lid on the container. If it isnt lined up absolutely perfect it tends to leak. You could make it tighter with a bit of ptfe tape. As these containers go into the machine lid down this is here mine leaks if Im not very careful.
Jun 13, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
437 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
