Question about Casio Exilim EX-Z750 Digital Camera
Battery When I put my battery on the charger the light blinks and the battery doesn't charge.
  • 477 Answers
You eather have a bad battery or charger. you can goto wolf camera and see if the battery will charge on their charger or you can goto ebay and get them both for pretty cheap. heres one combo on ebay.
http://cgi.ebay.com/Charger-Battery-For-Casio-NP-40-EX-Z750-Z57-Z50-Z1000_W0QQitemZ330225857192QQihZ014QQcategoryZ50510QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Posted on Apr 11, 2008
Does the battery have to go in a charger for charging
lila, yes you have to put the battery on the charger to charge the battery, if not the charger wont charge anything, after you put the battery on the charger hold, before that don't forget to equalize the pin charge with the battery there was a marking or emboss note negative pole and positive pole for the battery fit on it charge, then you can go for the electric plug. For additional note there is light indicator green for full battery, orange for the half battery energy and the last one is red light blink for the on going charge the battery. i hope it help, remember safety first.
Nov 11, 2015 | Samsung ST66 16 MP 5X Compact Digital...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
May 27, 2012 | Cell Phones
I have new batteries and charger but batteries will not charge
If your battery is totally flat some chargers see this as connecting to a short and will not charge. If the battery has a charge run it down some, my batteries often don't take much of a charge if any. Does the charger light up.Does the charger have any fuses on its out put wiring. Open the charger up, do you see fuses. When the charger is on do you see any blinking lights. If you get a blinking yellow light when hooked to a battery there is something wrong with the battery. Hope this helps
May 26, 2012 | Pride Mobility Products Health & Beauty
I was using my psp while it was charging and the charging light turned off, so i naturally assumed that it was fully charged. But a few minutes later the battery died and it wont charge when i plug it in....
Have you tried to remove the battery and put it back in and try to turn it on. Try removing the battery and putting the charger in and starting the PSP. If it starts, it might be the battery. If it doesn't, it's either the plugin for the charger or the PSP is just dead. If it does start with the charger, try putting the battery back in, if it charges awesome. If it doesn't the battery might be dead.
Sep 27, 2011 | Sony PlayStation Portable (PSP) Console
Fujifilm battery fully charged but camera says no charge or very little. Just bought a new Duracell Battery and Charger for my Fuji FinePix J10 Camera. Used the charge on the battery in the camera from...
Well you mentioned that it worked fine yesterday with the battery out of the box. That should tell you that the camera and the battery are both fine. The issue is likely the charger itself. Try recharging it again, and double check that you inserted the batteries correctly, and that any switches (such as for 2 or 4 battery charge) are set in the correct position on the charger. If this doesn't work, take the charger back to the store for exchange/refund as defective.
Jun 11, 2011 | Fuji FinePix J10 Digital Camera
My Duracell battery charger has a blinking red light.Use to be a constant red then green when it was charged. Now, just red..then blinking red..then not at all.
I had the same problem with flashing red lights. Both sides on a four battery charger. I swapped the batteries to another charger and the batteries were fine. They charged normally. I put some different batteries in the charger and the same flashing light situation. Those batteries also charged normally in a different charger. I looked closely at the back of the charger and, low and behold, "made in China". Why does that not surprise me. The bottom line, it may not be a battery issue.
May 08, 2010 | Duracell NiMH AA/AAA Battery Charger with...
Dewalt battery charger won't charge
As you know, solid red on your charger means that the battery is fully charged and the BLINKING red light means the battery is charging. Unless the light is blinking irradically everything is working the way it is supposed to. If the light is blinking irradically, the battery may just be too hot or too cold to charge ( like when you are driving many lags and your battery dies) and in this case simply wait 15 minutes to charge. If you get a fast blinking light still, the problem probably is with the battery.
Oct 07, 2009 | Dewalt DW056 18 Volt Cordless Impact...
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
Battery charger flashing red light
Clean contact points of both battery and charger with q-tips dipped in rubbing alcohol. This solved my problem with blinking lights and not charging of the batteries.
Nov 03, 2008 | Olympus Stylus 710 Digital Camera
Casio Exilim EX-Z750 Digital Camera Logo
91 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
