Question about Kenmore 56922 Side by Side Refrigerator
I whant to connect the water line for the ice maker but i dont seem to find the connection on the back of the fridge
  • 4,059 Answers
You may have to remove the cardboard from the right side looking from the back. It connects to the water inlet valve which will have two plastic tubes coming out of it. Most of them are blue. The water connector is usually the same as on a garden hose.
Posted on Jun 02, 2010
Whirlpool fridge making a low, intermitant groaning sound
Is it coming from inside fridge compartment or freezer compartment or from outside back. If it is from freezer compartment and you have no water line connected to ice maker. Then it might be just your ice maker trying to go into fake harvesting mode. Make sure the Icemaker is off. Icemaker arm should be up.
Oct 14, 2014 | Whirlpool Refrigerators
How do I hook up the plumbing. Do you have an exploded diagram of the back panel where all the water hook ups are at.
It depends on the refridgerator. Some have two inlet valves. Basically, you have a water line from the home. Usually copper line. You also will have two places for water lines on the opposite side of the inlet valve. Sometimes you may only have one. The line leading from fridge ( if ice and water through door) will hookup to the line where you have the fridge connactor. The quick connects to the inlet valve. The second one will be for ice maker. That water line runs up the back of fridge into freezer. Make sure you place the quick connects in the right spot. Process of elimination because some inlet valves wont let you change the hoses once installed. Connect the main water line from the home. Connect both quick connects dont connect water lines yet. Push the water thru the door botton and see which valve opens on the inlet. Which valve on inlet opened and allowed water to come out. That is for fridge and other is for icemaker.
If you need further assistance please feel free to contact.
Jul 24, 2011 | Refrigerators
Ice maker
The Ice maker requires a connection to a water supply. If you look behind the refrigerator you should see thewater fill valve connection. It is located on the right side on the bottom. A supply line kit can be purchased at a locat home improvement store like lowes or hope depot.
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Ice maker won't work
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Maytag MFD2562KES Stainless Steel Side by...
Icemaker not making ice
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
No water going to ice maker
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
Ice maker has stopped making ice
Check the ice maker to see if there are ice cubes in the ice maker. If so, there is a problem with the ice maker heater and / or motor. You may be able to rebuild the ice maker by replacing defective parts, but it might be easier to replace it as a whole unit instead. If there is no ice present, it is likely a problem with the ice maker water lines / solenoid.
There are usually two solenoid valves and tubing systems for these types of fridges. One actuates on demand for water whenever requested, and the other operates automatically to make ice cubes until the ice cube reservoir is full.
Carefully push/pull the fridge away from the wall.
Unplug the fridge from the outlet.
Shut off the water supply to the fridge.
Remove access cover (usually the on the bottom) from the back of the fridge. Follow the tube that comes from the top of the fridge (for the ice maker) down to the bottom of the fridge.
Inspect visually for sources of the leak on tubing and related parts. Carefully check by hand for leaks in areas not readily visible - including the back sides of all the tubing, too. There may be sharp edges that can cut if not paying attention. If a leak is found where the tubing connects to other parts, you may be able to simply remove the tube and cut it back an inch or so if there is enough slack.
It may require that some special fittings and parts be obtained to reconnect and some compression type parts are designed for single use. If this is the case, gather the parts and bring them to a local hardware store for assistance obtaining replacements.
If a solenoid valve is found to be the culprit, due to a crack, etc. a trip to an appliance parts store will be required - unless able to purchase online. Part prices can vary widely , depending on the source.
Once replacement parts have been secured, reconnect after disconnecting power & water supply lines. When satisfied with the installation, reconnect power and water lines and test.
Carefully slide the fridge back into position - taking care to not crush the power or water lines.
Dec 31, 2009 | Freezers
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Oct 06, 2007 | Refrigerators
Kenmore 56922 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
