How do I stop the brother MFC-215 fax from printing out fax reports?
  • 589 Answers
To turn off transmit reports:
Press Menu/Set
Press 2
Press 4
Press 1
Choose "off" by pressing the up or down arrow keys
Press Menu / Set
Press Stop/Exit
To turn off the Journal time periods (the default is set for every 50 faxes):
Press Menu/Set
Press 2
Press 4
Press 2
Press Menu/Set
Press Stop/Exit
Posted on Apr 09, 2008
Fax transmission reports
What you are explaining should work. If you need prior activity reports from previous faxes, you can press Function then 2 (Act. Report)
I think you might need to press Function, then 7 then 1
From the manual:
Transmission Verification (Xmit) Report You can use the Xmit Report as proof that you sent a fax. This report lists
the time and date of transmission, and whether the transmission was successful.
When the feature is OFF, the report is printed automatically only if an error occurred during transmission. If the report indicates NG, send the document again. If the report indicates you should check the readability of certain pages, resend those pages.
If you typically send multiple faxes to the same destinations, you may need a reminder to identify each fax transmission. You can select OFF+IMAGE or ON+IMAGE to print a portion of the first page of the fax message on the report.
1 For the FAX, press Function , 7 , 1 .
For the MFC, press Function , 1 , 7 , 1 .
2 Press or to select OFF, OFF+IMAGE, ON or ON+IMAGE and press Set .
3 Press Stop to exit.
Hope this helps you.
Mike
Nov 14, 2007 | Brother MFC 8300 Laser Printer
Have Brother MFC-7840W Printer/Fax How do you set the fax to print off confirmation reports
Hi there!
For you to setup the confirmation here's what you can do:
-Press Menu/set 2,4,1 -Press the Up or Down arrow key and select ON you can select On+Image to get a confirmation with the image of the document that u fax. -Press Menu/set to confirm -Press Stop/exit
To print the confirmation page for your last transaction just press Reports and press the up or down arrow key to select Transmission
Hope this helps! Thanks!
Jun 03, 2011 | Brother MFC 7840W Printer
HOW TO PRINT CONFIRMATION PAGE
You can use the Transmission Verification
report lists the time and date of transmission
(OK). If you choose On or On+Image, the
report will print for every fax you send.
If you send a lot of faxes to the same place,
you may need more than the job numbers to
know which faxes you must send again.
Choosing On+Image or Off+Image will print
a section of the fax's first page on the report
to help you remember.
When the Transmission Verification Report is
turned Off or Off+Image, the Report will
only print if there is a transmission error, with
NG in the RESULT column.
Apr 12, 2011 | Brother MFC 420CN All-In-One InkJet...
BROTHER MFC8840D IS THERE A WAY TO SHOW THAT I SENT A FAX TO A SPECIFIC PHONE NUMBER AT THE END OF MAY?
Possibly. The Fax Journal has the last 200 faxes (incoming or outgoing). Press Menu then select Fax (up and down arrows). Press Set, and use the navigation keys until Setup Reports or Report Settings appears. Then press Set and use the navigation keys to find the Act. Interval or Journal Period. Press Set again and a length of time for the Journal (anything but off). Press Set again. (If you use the 7 day count-down, you will get additional queries for day of week and time of day for the start of the count-down.) Press Stop/Exit and the Activity Report will print when 200 faxes are in memory, the memory is full or the desired time frame. (The setting of 50 faxes will print at every 50 faxes.) After printing the report, these entries will be deleted.
I hope this helps.
(if the report was already generated, you won't get the old entries. Similarly if the memory was cleared after an Out Of Memory error, you won't find this entry. If Fax Storage was on, you may be able to actual get the original Fax. Menu > Fax > Remote Fax Opt > Print Fax or Print Document. Then Start and when all stored Faxes print hit Stop/Esc.)
Aug 05, 2010 | Brother MFC-8840D All-In-One Laser Printer
How can I print a history report on my Brother MFC-7220 Plain Paper Laser Fax?
The report you want is called "Fax Journal, and it's number is 4.
Press "Reports" button (in the upper-right corner of the panel), then either go down (using up/down arrow keys) to "Fax Journal", or press number 4 directly, then confirm with "Menu/Set" key.
By the way, click here to download a PDF manual for your unit.
Good luck, and please leave testimonial if helped :)
Jul 06, 2010 | Brother MFC-7220 Plain Paper Laser Fax
How to program brother mfc 8460n to print confirmation sheets for when a fax is sent.thanks
Press 'Menu', '2', '4', '1'. Report Setting is displayed. Press down arrow to select "on + image". Press 'OK'. Press 'Stop/Exit'. Reference page 70 in this link to MFC 8460n on the Brother site.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8460N_8660DN_8670DN_8860DN_8870DW_EN_1586.PDF
Nov 04, 2009 | Canon LaserClass 9000L Plain Paper Fax
My fax BROTHER MFC-215C does not print after RECEIVING. it also does not send fax after scanning.
The solution, finally, was very simple: To disconnect the mains voltage, for several days, from BROTHER MFC-215 .
After that, I was successful to receive and print the incoming faxes.
Thank you very much for your willing to help.
jacobr05
Mar 27, 2009 | Brother Multi-Function Center® MFC-215C...
Printing report on received faxes
Fax machines usually only store the last 50 transactions
Aug 05, 2008 | Brother MFC-8220 Fax
158 people viewed this question
k24674
jasbo
jasbo
