Question about Samsung ML-1630 Laser Printer
How do you take printer off of idle mode - Samsung ML-1630 Laser Printer
Is there a sleep setting on a gk420d after being idle for 5 mins
There is no sleep mode on the Zebra G series.
Contact www.lancerlabels.co.uk for expert help with Zebra thermal Printers
Feb 12, 2015 | Zebra GK420D Direct Thermal Label Printer
How to change the idle to active on my
It should do that automatically when you print something. That is just a power saving mode, ignore it.
Nov 29, 2014 | HP Office Equipment & Supplies
IDLE MODE
check the status light pattern maybe the printer has a problem. but if there is no error on the printer itself then you have to check for the connection between the machine and PC. re-install the correct printer driver.
Apr 27, 2013 | HP LASERJET P1005 Printer
How to get hp 1350 out of idle mode?
The best way to get the printer back from sleep mode is to disconnected the power cord from back of the printer ( while the printer has power ) and wait for 30 seconds and connected it back.
Regards,
Suhail
May 20, 2012 | HP PSC 1350v All-In-One InkJet Printer
I have an HP d2680 printer hooked up to a mac computer. I always has worked fine, but now it says it is on idle and I can not print at all. It says to set as default, which I have already done. I...
Does it say it is 'idle' on the computer or on the Printer itself?
If the message is on the computer: 1. Top left of screen, click the Apple icon, then click System Preferences. 2. Go to 'Print and Fax'. 3. You should see your printer listed. Highlight your printer by clicking on it once, then click the 'Minus' button to delete the printer. 4. Click the 'Plus' button and go through the process again of reinstalling your printer.
It seems this has fixed other people with the same problem and printer as you, I hope this works for you.
Thanks for using FixYa.
Jul 27, 2011 | Computers & Internet
How I can fix Canon mx 868 service mode idle problems?
My MX870 Canon Printer is in idle status. How do you activate the printer?
Mar 29, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
Feb 04, 2011 | Brother Office Equipment & Supplies
My printer is in idle mode and will not print. How do I fix or change idle mode so it could print?
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 20, 2009 | Dell 1710n Laser Printer
Samsung ML-1630 Laser Printer Logo
435 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
