Question about Microtek 815C 18" Flat Panel LCD Monitor
Open the case
I have removed the screws, but i cant open the bezel
  • 186 Answers
The bezel is hook up to the panel.. to open most LCD.. you will need to pry slightly... it takes time to figure out where to pry.
Posted on Jun 02, 2010
Lp2417
Remove all the screws, then unsnap the bezel
Aug 20, 2012 | Computers & Internet
Have a samsung 203b (R) C lcd monitor that i believe needs caps replaced cant figure out how to open case no screws probably just plastic clips holding bezel on
The case is held together with plastic finger hooks type setup, it goes together real easy but hard to separate. I use thin flat blade screw driver to crack it open starting at the center bottom edge and then work your way around, when you get the bottom, left and right side part way open, you will then lay it face down and then pull the back up, just watch out for the cable attached to the front bezel.
http://s807.photobucket.com/albums/yy352/budm/SAMSUNG/
Jun 30, 2011 | Samsung SyncMaster 203B LCD Monitor
I want to replace the LCD screen myself but I can't find any video that shows me how. All of them show laptops that screws on the front of the bezzle and mine doesn't. How do I get the bezzle off?
Here's how to remove a screen for a laptop with a front bezzle instead of just front screws:
1. Power down your laptop. Disconnect the power cable and any peripheral devices from the laptop. Close the LCD screen, flip the laptop over and remove the battery from the bottom casing of the laptop.
  • 2.Flip the laptop over, and then open the LCD screen all the way. Remove the rubber screw covers from the front LCD bezel. The screw covers will be located on the front of the panel, or along the side edges, depending on your laptop's make and model.
  • 3.Remove the retaining Phillips-head screws from the front LCD bezel. Insert a flat-head screwdriver into the gap along the outside edge of the LCD panel. Start to pry off the front bezel. Work your way around the entire LCD panel until the front bezel is separated from the panel.
  • 4. Remove the the bezel from the LCD panel and set it aside.
    Source: http://www.ehow.com/how_6759851_remove-bezel-laptop-screen.html
  • Mar 19, 2011 | HEWLETT-PACKARD G72260US Notebook
    Need to replace led screen on a hp g62-b13sa laptop but cant get outer casing off took all the screws that i can see out but casing still wont come off
    The detailed step by step solution its kind of long so I'm going to make it short. If you want to, let me an email to send you a detailed .doc file.
    I'll show you where the screws are so you check.
    .Flex the inside edge of the top (1), the left and right sides (2), and the bottom (3) of the display bezel until the bezeldisengages from the display back cover.Remove the display bezel (4). luis009_5.jpg
    Feb 21, 2011 | HP G62144DX Laptop
    Need to remove and repair headlight motor on a 1988 corvette
    REMOVAL & INSTALLATION 1984–88 Vehicles
    1. Open the hood, then turn the headlights on.
    2. Detach the headlight motor wire on the outer side of the headlight.
    3. Turn the headlights off (the disconnected light should stay open).
    4. Unfasten the 4 screws at the bezel. There are 2 at the front and 2 at the sides. Fig. 1: With the hood in the raised position, unfasten the Torx® screws from the outer side of the headlight bezel/trim piece 91036p23.jpg
      Fig. 2: You must then remove the screws from the inner side of the bezel/trim piece 91036p24.jpg
    5. Remove the bezel. Fig. 3: Remove the first of the top bezel/retaining ring screws . . . 91036p25.jpg
      Fig. 4: . . . then remove the remaining Torx® screw 91036p26.jpg
      Fig. 5: Lift the bezel/trim piece away from the headlight assembly 91036p27.jpg
    6. Remove the retaining spring by carefully using a hooked end tool, such as a cotter pin removal tool to move it to the side.
    7. Remove the headlight from the aiming pins by rotating the headlight toward the center of the car.
    8. Unfasten the 4 retaining ring screws, then remove the ring. Fig. 6: With the hood closed, you can see the 4 headlight retaining ring screws (1) and 2 aiming screws (2) 91036p28.jpg
      Fig. 7: Remove ONLY the 4 retaining ring screws, do NOT touch the aiming screws 91036p29.jpg
    9. Remove the headlight pump from the mounting bracket, unplugging the socket as you pull it away. Fig. 8: Remove the headlight away from the mounting bracket, unplugging the socket as you pull it away 91036p30.jpg
      To install:
    10. Install the headlight bulb, making sure it is plugged in properly.
    11. Position the retaining ring and secure with the 4 screws.
    12. Position the headlight into the aiming pins. Move the retaining spring back into place.
    13. Install the bezel and secure with the retainers.
    14. Turn the headlights on, then connect the headlight motor wire.
    15. Turn the headlights off. Both should lower.
    16. Close the hood. Check the aim of the headlights, and adjust if necessary.
    1989–96 Vehicles
    1. Open the hood.
    2. Open the headlight door halfway. This can be done either by turning the headlight switch on, then back to the parking lamp on position, or by the manual headlamp control knob (which is located on the inboard side of the headlight door). NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
    3. Remove the screws from the front of the headlight bezel. NOTE: Before removing the screws from the side of the headlight bezel, place your hand under the bezel to support and prevent damage to it.
    4. Remove the Phillips head screws from each side of the headlight bezel.
    5. Remove the bezel by pulling it straight out from the engine side of the hood. Fig. 9: View of the headlight bezel mounting 91036g28.gif
    6. Unfasten the screws from the headlight retaining ring.
    7. Remove the headlamp from the assembly, unplugging the electrical connector as you are pulling it away. Fig. 10: Exploded view of the headlight assembly 91036g29.gif
      Fig. 11: Location of the headlight mounting and aiming screws 91036g30.gif
      To install:
    8. Attach the headlight electrical connector.
    9. Position the retaining ring and install the screws securing the ring to the headlight.
    10. Position the bezel in place on the headlight assembly.
    11. Install the screws on each side of the bezel and tighten to 51 inch lbs. (5.8 Nm).
    12. Install the screws on the front of the bezel and tighten to 17 inch lbs. (1.9 Nm).
    13. Cycle the headlamps, then close the hood. Check the headlight aim, and adjust if necessary.
    Jul 07, 2010 | 1988 Chevrolet Corvette
    Cant remove door pannel on driver side 04 gmc seirra
    1. Remove the door handle bezel.
    2. Insert a flat-bladed tool between the door handle bezel and the trim panel in order to release the handle bezel tab retainers.
    3. Remove the door trim panel upper extension.
    4. Release the upper extension by pulling outward on the front edge in order to release the upper retainer clips.
    5. Remove the upper extension from the trim panel by lifting up and out.
    6. Using a suitable flat bladed tool, gently pry the manual lock lever from the door trim panel. Remove the trim panel screw.
    *Remove the screw (2) from within the opening where the manual door lock lever resides.
    *Remove the screw (3) from the opening in front of the armrest.
    *Remove the screw located beneath the map pocket, if equipped.
    7. Carefully slide the trim panel up in order to release the retainers from the door. Disconnect the electrical connectors.
    Note: the top part of the door panel is not separate from the bottom. The "upper extension" is just the small triangle piece directly behind the mirror on the interior.
    Simplified instructions
    Remove the bezel around the door handle.
    Pry out the manual lock.
    Remove the 3 or 4 screws depending on options
    Slide the door panel up off of the engagement tabs.
    Good luck and thank you for using Fixya.
    Mar 16, 2010 | 2004 GMC Sierra 2500
    Navitimer 2 rotating bezel has gone very stiff to turn how can i free it up?
    This depends on what exactly is causing the problem. If the bezel is bent from a sharp blow it would have to be replaced. It could be there is dirt under the bezel. To clean this there are two possibilities. If your bezel has screws around the outer edge they will need to be loosened or unscrewed to remove the bezel. These are small screws so be careful you don't loose them. The bezel should then lift off. Clean it with mild soap and water and dry it well. Be careful of the bezel spring. it is easy to break the little fingers. Wipe off any dirt on the case and set the bezel spring and bezel back on the case. Use Red locktite on the screws and reinstall them. If you have markers on the bezel that come off when you remove the screws be sure you keep track of them and the screws that went with them.
    If your bezel does not have screws but fake ones then the bezel should be removed by a qualified watchmaker because the bezel could be bent or damaged when removed.
    Hope this helps.
    Ken
    Yellowstone Watch Inc.
    Oct 01, 2009 | Watches
    Left hinge busted
    Dunt open and close lcd too muh otherwise it will damge your lcd cover and lcd bezel than it will cost u more. Remove all lcd screw cap and remove screws than slowly pull out lcd bezel and check is really hinges is gone or screw is loose. For Key u have to check it that any of latch of behind key is broken or fine. If its fine than just put that parallel to other keys and press it. it will seat back on jumper.
    Jul 28, 2009 | HP Pavilion dv4000 Notebook
    How to disassemble monitor Dell 1800fp ?
    Remove the base by the button release or 4 screws on the back. On the bottom of the monitor near the corners you will find two thin slots where you can insert a thin wide blade screwdriver or pry tool. Very gently pry the back from the bezel toward the center from both of these slots until the bottom is seperated, then contilue from the slots around the corners and up the sides until you have seperated the entire back from the bezel. Lay the monitor on the bezel and remove the back ( do not try to remove the bezel, at least not yet). Lift the tape that secures the ribbon cable from the bezel buttons to the logic board. Unplug the ribbon cable from the logic board by pulling on the connector (not the cable). Remove the cable covers from the back of the case (one has a screw, the other has a lift tab) and disconnect the lamp connectors and ribbon cable connectors (do not pull on the wires). remove four screws and lift the metal back from the screen.
    May 15, 2009 | Dell UltraSharp 2001FP 20.1" LCD Monitor
    Manual showing how to remove DVD-ROM Drive from case for Presario 5000?
    REMOVE CASE SCREWS FROM REAR CASE COVER.CASE COVER SLIDES OFF FROM FRONT TO BACK.DVD IS HELD BY 4 SCREWS TWO PER SIDE DISCONECT POWER LEAD AND RIBBON CABLE YOU GOT IT,RICHARDM69
    Dec 02, 2008 | Compaq Presario 5000 PC Desktop
    Microtek 815C 18" Flat Panel LCD Monitor Logo
    60 people viewed this question
    Top Microtek Computers & Internet Experts
    William Miller
    William Miller
    John Anderson
    John Anderson
    solver2010
    Are you a Microtek Computer and Internet Expert? Answer questions, earn points and help others
