Find badsector In file FAT32, how i find bad sectors and how i recover it.
    Sergeant:
    Champion:
  • 277 Answers
The bad sector cannot recover... is continuing increasing the bad sector... you need to replace your hard disk...
Posted on Apr 09, 2008
I've a Samsung G2 Portable HX-MU050DC/GW 500GB. - I was using it fine on PC1 when a Scan Disk Message Window (bad sector) popped out. I did a scan disk, nothing happened and continue copying and pasting...
when you see "bad sector" you need to not only run scandisk, you need to tell it to "automatically repair bad sectors" if you didn't do this, then you have written to the bad sectors and that data can not be retrieved. As for the MAC issue, you didin't say what format your HDD was, if it was FAT32 it should mount on MAC, but not if it is NTSC as MAC can't read it. If I were you I would copy all the files from your HDD to a wiindows machine and then run scandisk again, only this time make sure to auto repair, these sectors will now be gone, and its not a great loss and does happen quite ofter unfortunately. The data you have written to the bad sectors "CAN NOT" be recovered, you might get part of it, but most likely not. Good Luck
Mar 24, 2011 | Samsung G2 Portable External HX-MU050DC/...
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
Bad sectors on hard drive HP model number BD0728856A 72.8GB 10K rpm Can I get another HDA to replace this one?
yes better u have to change the HDD. Else u have to remove the badsector using dos os. Its an long process. after u have removed the badsector then also its running slow. Better u have to change the HDD.
Cheers
Sep 19, 2009 | HP SCSI Hard Drive
Many Bad Sectors fat32, trying recovery disk
It sounds like your HDD is faulty, usually a hardrive can operate with bad sectors but still a risk.
My best advice would be to get a new HDD and recover back on to the new one, even if you did manage to recover onto your current one you may still have problems in the future.
I usually only allow a HDD to fail S.M.A.R.T tests 3 times over any given period and then I just replace them.
Thanks
Sep 05, 2009 | Acer Aspire 3000 Notebook
Corrupted and unreadable hard drive
You need to hook this hard drive up to another system as a slave/second drive, ask and I can tell you how if you need to know how. Then you need to run r-studio to recover the data.
What operating system was on the drive?
I would use w w w . r-studio . c o m
I have no association but it works well for this type of problem. You can scan for free and only buy it if it finds your data.
Aug 08, 2009 | SimpleTech 1TB SimpleDrive Pro Duo...
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
My PC often Crashes, when I opened it! it has badsector in HDD !
You should back up all your important files and installation code, drivers. It is almost 2.5 years I assumed your hd is also of this age. Its a normal wear and tear.
But for the meantime delete junk files in your disk, defragment it if still large space is available. Unload your drive with files. Use registry cleaner, Ccleaner is good at it, actually it has many features, and its free. Uninstall some unimportant application.
I think Hard disk drive regenerator software just check it out, its for the bad sector problem.
Hope this input helps
Apr 26, 2009 | Computers & Internet
Bad sectors
Use the following link to download the software, which helps u to detect as well as completly remove badsectors, but before u do tat, here is the answer for wat is bad sectors..
Hard disk drive is an integral part of every computer. It stores all your information. One of the most prevalent defects of hard drives is bad sectors on the disk surface. Bad sectors are a part of the disk surface which contains not readable, but frequently necessary information. As a result of bad sectors you may have difficulties to read and copy data from your disk, your operating system becomes unstable and finally your computer may unable to boot altogether.
When a hard drive is damaged with bad sectors, the disk not only becomes unfit for use, but also you risk losing information stored on it. The HDD Regenerator can repair damaged hard disks without affecting or changing existing data. As a result, previously unreadable and inaccessible information is restored.
ths is the software
A powerful hard disk tool that can detect and repair physical bad sectors on a hard disk drive surface and regenerate hard disk.
http://www.4shared.com/file/49739096/5f24d2c2/HDD_Regenerator_151_Full.html?s=1
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Computers & Internet Logo
David Payne
David Payne
