Question about LG WD14311RD Front Load Washer / Dryer
My LG TROMM WD-14311RD washer and drier write dE
My LG TROMM WD-14311RD washer and dryer write dE in the display... wat does it mean?
  • 76 Answers
SOURCE: LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Posted on Dec 03, 2008
SOURCE: LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
Posted on May 31, 2009
  • 1294 Answers
SOURCE: need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 21, 2008
  • 334 Answers
SOURCE: LG Tromm WD R8012 Owners manual
GO TO THIS SITE AND LOOK FOR YOUR MODEL NUMBER UNDER WASHERS. http://www.lge.com/us/support/product/support-product.jsp GOOD LUCK.
Posted on Jun 11, 2009
MNTECH
  • 1543 Answers
SOURCE: LG TROMM displays LE
LE stands for Load Error,
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Jun 21, 2009
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Hi my LG WD-14311RD washing machine refuses to unlock. Cannot open the door,just remains locked.
My model no is LG WD-14331 AD the door just remains locked cant open i think the handle inside plastic hv broken how to solve can u send some one come to repair or .
BR Chow
Jul 29, 2011 | LG WD14311RD Front Load Washer / Dryer
My LG washer write dE in the display wat dit it mean
that's a door error code. if your door is closing properly, it's more than likely you have a defective door switch module.
May 24, 2010 | LG WD-1280FHD Front Load Washer
WASHING MACHINE DOES NOT GO ON
Check your display panel again- there is no such error code for the LG WD-3245RHD. You can have: "dE", "tE", "FE", "PE", "CE", "LE", or "dHE" but there is no "D5" error code.
Aug 24, 2009 | LG WD-3245 Front Load Washer / Dryer
Jun 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WD-12331. Front load washer and dryer machine
since it is a washer-dryer, the lint trap is in line with the drain. you have to empty the drain basket. there's an access door on the bottom left, first take the little tube out and drain the remaining water, then open the large drain cap to the right and clean out the trap. once you're done put it all back together and it should work. you're supposed to do this every few months. It was too much for me to deal with so i ended up buying a separate dryer and just use the washer .
Jul 28, 2008 | LG WM-2277HW Front Load Washer
LG WD14311RD Front Load Washer / Dryer Logo
260 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
