Question about Samsung SGH-A137 Cell Phone
It takes hours to get a signal after it is turned on, the battery is full charged and after it gets a signal it is full.
    Scholar:
  • 106 Answers
If your phone is unable to find a signal after 15 minutes of
searching, a Power Save feature is automatically activated. If
your phone is active, it periodically rechecks service availability
or you can check it yourself by pressing any key.
Anytime the Power Save feature is activated, a message displays
on the screen. When a signal is found, your phone returns to
standby mode.But u are saying it takes hours to get the signal.I think it
Posted on Jun 02, 2010
  • Mahalingam M
    Mahalingam M Jun 02, 2010
    standby mode.But u are saying it takes hours to get the signal.I think it u have to contact the nearest service center for solving this problem.
How long does it take to charge this battery?
According to their website, it takes one full hour to completely charge this battery. That means that if the battery is totally empty, you will only need to plug it in for one hour until it reaches full charging capacity.
Feb 16, 2014 | Battery Biz HiCapacity B9583 Digital...
How long does the battery takes to charge
New batteries are shipped partially charged. Before you start using your phone, it is recommended that you install and charge the battery. Some batteries perform best after several full charge/discharge cycles.
Battery performance depends on many factors, including network configuration, signal strength, the temperature of the environment in which you operate your phone, the features and/or settings you select and use, items attached to connecting ports, and your voice, data, and other program usage patterns. To increase battery performance you can turn off Bluetooth, GPS, Mobile network, Wi-Fi, notifications and other options that you may not frequently use. You can also decrease the screen brightness, the Screen timeout time.
Your battery can take up to 3 hours to fully charge using the AC charger. It will take much longer using the USB as that is the trickle charge function.
Aug 21, 2011 | HTC Cell Phones
I have a scootamart large scooter,not sure if 6 or 8 mph.batteries have been checked and are perfect but can only travel 5 or 6 miles on a full charge.what can be wrong.
Hi. How many amp/hours are your batteries?
Who tested your batteries, and how did they test them.
I have had batteries tested by an auto electrical technician, who said the batteries were OK. I knew at the time that the batteries were faulty.
What he did was do a short high current test, that he would normally do on a car battery.
To test batteries in a scooter you have to do a constant current test on fully charged batteries, and monitor the battery voltage. When the battery voltage drops to 10.5 volts across the 12 volt battery, that is considered a flat battery. Take the time elapsed for the test, and you can roughly work out the amp/hour rating of your batteries.
The amp/hour rating of a battery is worked out on a 10 or 20 discharge. A 40 amp/hour battery can supply 2 amps/ hour for 20 hours.
If you take 20 amps per hour, you will not get 2 hours of use. You will probably only get 1.5 to 1.75 hours of use. The more current ( amps ) you take out of a battery, the less amp/hours it will supply.
The best way to test your batteries is a constant current test, but they take a few hours, or try new batteries.
Also how long do you charge your batteries for. Most chargers need to be on at least over night to fully charge your batteries.
Some chargers have a green LED that comes on when the batteries are nearly full. This green LED is a guide only, and most batteries still need a few more hours to do a full charge.
Good luck. Neil.
Jun 10, 2010 | Health & Beauty
Phone shows full battery then goes dead in an hour.
If you turn your phone on the very first time you use it you are suppoesed to charge it for ten hours. or not quite ten but what I do is i charge it all night and turn it off. this way you get sleep and in the morning your phone should be fine. if not reset the settings this should do it.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
How long does it take to charge the battery to a full charge...thanks,judy....on a presario V2000
usually 8 hours is what is suggested when you get a new battery. i like to burn down the power on the battery completely till it turns the unit off, then let charge for 24 hours just to reset the battery correctly.
Jul 19, 2009 | HP Compaq Presario V2000 Notebook
Yellow / green light will not go off when charging
Its likely the batteries will take at least several hours to fully charge, if not more. NiCad batteries are slow charging and usually need 4-6 hours for a full charge. Keep them on longer or even overnight but make sure you remove them in the morning. You will probably find the light turns green after 4-6 hours of charging. If lights stay yellow and green after 12 hours of charging, it may indicate a fault in the battery itself where it will not accept a charge.
Jun 18, 2009 | Ryobi Multi-Volt Battery Charger
How long should I let my battery recharge?
If you have the PS130 12v Battery, and the one-hour rapid charger from Black and Decker, then, in theory, it should only take an hour to charge the battery (according to them). However, I would leave the battery on charge for at least several hours to guarantee a full charge each time. That battery is a NiCad cell battery, and these typically take longer to reach a full capacity charge. So give it a few hours at least, but it probably wont hurt it if you left the battery on charge even overnight either... But don't let them charge for longer than 18 hours maximum!
Apr 11, 2009 | Black & Decker PS130 12V Battery
Battery does notfully charge
I have a similar problem but when I use mine, it lasts 3hours per bar on the meter. It only does up to 98% and it overheats. If you take it off and let it cool and monitor it as it charges, you can get a full battery. Take it off charge around 70% and turn it off. Wait 2 hours and put it back on charge until it reaches 100 then take it off and it is charged. To see the battery charge
My Computer > Sansa Clip ?gb (Right-Click) > Properties
Look down at a battery shape with a green bar and a percentage beside it.
Mar 28, 2009 | SanDisk Sansa Clip MP3 Player
Charging
i would say it all depends on how many AH your battery is and what amp your charger is they differ between 8 to 14 hours that is for new batteries as a battery gets older the less time it takes to charge so if your batteries are getting fully charged in 2 hours its time to start thinking of changing them
good luck and hope this helps
clive
Jan 17, 2009 | Pride New Mobility Legend 4 Wheel Scooter
I charge my LG KU990 full over night within 12 hours the battery
You just have to charge it fully but not for long as soon as it turns full battery then swithch ur phone off then take the battery out for a sec then put it back on then turn ur phone on then it will work for a longg timeee kk..
Nov 13, 2008 | LG KU990 Viewty
Samsung SGH-A137 Cell Phone Logo
104 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
