Question about HP Officejet J3680 Multifunction Printer InkJet
How to fax multiple papers - HP Officejet J3680 Multifunction Printer InkJet
    Problem Solver:
  • 13 Answers
Hello t,
Put them all in the feeder at one time... Not too many though and make they're nice and neat. Nothing sticky should be on them like tape or glue.. No paper clips or staples either. Folded or damaged corners are trouble as well.
If your machine is like the one in the picture here, it might be fine with up to 30 pages.
Dial up the fax machine you want to send to and they shoulg all go thru but one at a time. If they don't go in one at a time and get jammed in the feeder part of the machine there is something wrong in the machine and it needs to be serviced.
Hope that helps! Let me know!
RAy
Posted on Jul 14, 2010
When sending a multiple pages fax....after every page, it says line error. Freaking annoying.
Check Your Drum on the back cover You may have some paper are stuck in to il .... and make sure your termal paper are on the right side check cafully the way you install your Termal paper
Sep 22, 2010 | Sharp UX-P115 Plain Paper Thermal transfer...
Paper feed on send
Have you checked that you have no paper jams?
Nov 09, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Pulls multiple pages when sending fax
Problem :
feeding paper
Solution :
Clean in the feeder section all the rubber pads that pull the paper with alcohol
Aug 19, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Am I able to fax to multiple recipients with canon lc 2050p?
Yes. Here is a link to your Canon Laser Class 2050P fax machine's User Guide. Reference pages 5-1 through 5-28 for Speed Dialing, One-Tuoch Dialing, and Group Dialing. Speed Dialing must be set up before Group Dialing can be assigned. Group Dialing will accomplish the multiple recipients sending.
http://www.actcopiers.com/Manuals/Canon_Laser_Class_2050P_User_Manual.pdf
Dec 14, 2009 | Canon LaserClass 2050 Plain Paper Fax
Upon incoming message, multiple sheets of paper
Switch the machine off,remove the document and plain paper tray,at the intake of the plain paper parth there is two gray rollers,Clean them with a strong soap sullution,just make sure the main board dont get wet.
Nov 19, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Feed tray pulling multiple pages
prior to the issue ,it can be the sign of wear and tear of the feeder seperation pad .may i know is the fax heavily utilise.if yes get the part to change ,if no try to change your paper or frequently fan the paper it can be highly moisture present on paperand try to minimise using reuse paper it may shorten your machine lifespan.good luck thanks pls rate me!!!!
Aug 27, 2009 | Canon LaserClass 2050 Plain Paper Fax
When i fax multiple sheets, they stick together
The separator pad is probably toast.It is a little white or gray rubber pad on the scanner assy.If it is intact, clean it .If not it must be replaced
Mar 24, 2009 | HP 1050 Plain Paper Inkjet Fax
Paper jamming in fax
look for a piece of paper in the paper path. clean all paper feed rollers
Jun 11, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Multiple faxes
you can send it seperat only
Sep 19, 2007 | Canon LaserClass 2050 Plain Paper Fax
HP Officejet J3680 Multifunction Printer InkJet Logo
32 people viewed this question
Seeker5211
Seeker5211
