Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker line poped out of back and water line going to ice maker frozen
    Scholar:
  • 59 Answers
Sometimes over the winter months the tube going to the ice maker can become blocked with ice and cause this tube to pop out.
1. With the water supply going to your refrigerator on take a look at the end that popped out and see if you can see it drip at all. If it does not drip just clear the ice out of the ice maker fill tube, then replace the line that popped out and you will be good to go.
2. If you do see a drip come out of the end that popped out you will need to trace that line back to the valve its connected to and replace that valve.
Thanks for asking.
Posted on Jun 02, 2010
Whirlpool ice maker will not fill with water
1st check to see if fill tube is frozen that goes through back freezer wall to feed water to ice maker. If it is, thaw it and replace water valve. If not frozen, then you must determine if water valve or ice maker is bad. You must determine if Ice maker is sending voltage to valve. If it is, replace valve. If it's not, replace ice maker.
Sep 03, 2017 | Whirlpool Refrigerators
Ice maker not making ice water dispenser works well
There are 2 solenoids, one controls the water dispenser the other controls the ice maker water supply. Follow the tubing down the back of the refrigerator to find the ice maker solenoid. If the line is frozen between the back of the refrigerator and the ice maker it won't make ice either. If the line is frozen you need to check to see if the solenoid is leaking, this allows a trickle of water to continously flow through the lina and freeze.
Jan 08, 2011 | Refrigerators
Ice maker stopped working
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Mar 02, 2010 | KitchenAid Architect KBRA20ERSS Bottom...
Ice maker is not making ice, water flow line is good, how can i check to see if the line close to icemaker is frozen
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jan 22, 2010 | Refrigerators
Ice maker won't work. Water is coming out of the back of the unit
IT SOUNDS LIKE YOUR ICE MAKER FILL TUBE IS FROZEN AND YOUR LINE POPED OFF. YOU NEED TO DEFROST THE FILL TUBE MANY TIMES THIS HAPPENS FROM POOR WATER PRESSURE EITHER YOUR HOUSE LINE OR THE REFRIGERATOR FILL VALVE.
Jan 13, 2010 | Refrigerators
Ice maker is not getting water, water dispenser is. there is notheing frozen but the line leading to the ice maker doesn't have any water in it
Dec 30, 2009 | Frigidaire FRS26R4A Side by Side...
Water filter keeps poping out when ice maker kicks on
replace filter if restricted. if ice has formed in tube coming into ice maker, remove ice and replace water valve. this is causing back pressure and poppin line off.
Jul 25, 2009 | Refrigerators
Water solenoid to ice maker not working. Check with ohm meter..should NOT read open
Water line to Ice maker frozen solid. Look at water inlet to ice maker....is ice present in line?
Evaporator coils frozen over with ice. Will cause water line to freeze and unit will slowly thaw.
Try unplugging the unit for several hours and see if it starts to cool normally again. If it cools normally then check heater element and Defrost Thermostat.
Nov 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker not working
The machine water pressure is low cheak the inlet water pressure and cheak the machine water in let line any block
Jun 21, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
91 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
