Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Refrigerator get's hot when plugeed in
I just bought a whirpool ref. and plugged in. after 20 minutes i noticed that the divider boards in beetwen the freezer and the fridge it become very hot? had to umplug, why is so?
    Scholar:
  • 59 Answers
It is normal for some heat to be generated in this area. However there is something you need to check if you feel the heat is excessive.
In the lower rear of your unit is the compressor and a fan. You need to look the see if this fan is operating. Its quite common for this fan to get jammed during a move because the insulation gets caught in the blades of the fan. It is very important this fan is operating as it cools the freon and oil which in turn cools the compressor. The heat you are feeling is part of the warm side of the circulating system that was installed there to help keep that area dry and your door gaskets free of mold.
Thanks for asking.
Posted on Jun 02, 2010
Condenser fan problem on Kitchenaide Refrigerator - kscs23inss01
What you are going to find is this... Your COILS under the Plastic are Condensating and FREEZING and then this is what is causing the On /Off of the Temp. You have to DEFROST the COILS (Under the Plastic) and remove ALL the ice and Moisture. Once you get this problem resolved, it will work perfectly. This problem was caused by the Condenser Coils being Dirty and and the Switch on Top, Under the Plastic from being unable to work properly. This is a time consuming issue but easy to do. DO NOT SCRAP or BREAK the ICE after you take the Plastic off, use a hair dryer or Hot Water and make sure the Drain Tube is completely cleaned...
Mar 03, 2014 | KitchenAid Refrigerators
The strip between freezer and refrig become hot then cools off. It's like it is going thru a cycle. We cleaned the coils underneath, but it is still getting hot and then in about 15 minutes, it's...
When you cleaned the coil underneath did ya notice that their was air being blown out their by a fan,having clened the coil was a good start but if the fan by the compressor isn't running that divider between the ref/freezer will be hotter than normal( its normally warm and thats ok),so check that the condenser fan is running and that it seems to running at a good speed.
GENE
Sep 23, 2011 | Whirlpool GC5SHEXNS Side by Side...
Freezer not working but refrigerator is...I smelled wires getting hot and unplugged the whole unit and waited about 30 minutes then plugged it back in and noticed the next morning that the refrigerator was...
refrigerator can not work unless freezer does / as the ref get's it cold form the freezer in 99 % of all f-ref units . so the burning smell may have been the def heater's look for frost build in back of freezer and possible a evap fan failure . / make sure the fan in freezer is woking .. mm
Jul 03, 2010 | Refrigerators
Whirpool side by side refrigerator hot door gasket
Good day,
The first step is to clean the coils properly. Remove the back cover, and make sure the cooling fan is running. At this point, unplug the machine and with a wand and a push pull vaccuum blow the dirt out of the coils from back to front.
Yes , it's filthy and ugly, but the only proper way yo clean it.
Make sure the cover in the back is properly reinstalled. (See my tips). At the beginning, the divider will be fairly hot, but should slowly cool after enough running time to get the machine to it's normal temperature.
Apr 30, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My Whirpool ref. stop making ice. There is water
feed valve most likelly cause remove wtr. line if water comes out water valve is somthing to look at if it has power
Jan 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The center divider (between the doors) gets so hot you can't touch it. Other than that- it works and cools just fine.
ok that is entirely normal
that is your moulion heater, it is ment for two things
a. it keeps your seals soft and plyable
and b. it controls hot air entry to the unit when you open the door
it offsets the heat barrier with the door open,
that is what stops humidity from building up oin the machine
Oct 16, 2009 | Samsung RS2630WW Side by Side Refrigerator
Water driping from freezer to ref.I khow its pluged
The easy way to fix is unplug appliance - take back panel off freezer - melt ice in pan below evaporator - when ice is melted and you see drain tube mop water up with paper towel - with a measuring jug pour hot water into pan/tray below evaporator...repeat this at intervals of a few minutes 2-3 times moping water up each time with paper towel - next find something flexible to clear blockage in drain tube, curtain wire works - when you see water suddenly drain down tube blokage has cleared.
put back together and plug in..you are good to go.
Hope this helped, if you need any further assistance of have questions please feel free to comment again.
Jun 23, 2009 | Refrigerators
GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
