Question about Office Depot Office Equipment & Supplies
Ativa AT-14X shredder. showing door open red light when door is shut.
exspert
  • 55 Answers
SOURCE: Shredder won't turn on
ok " if the ready light did not come on it's telling you that there is no power sound like the plug in transformer is no good .
you can check that transformer , with a multimeter, see if you have the right voltage.
Posted on Jan 27, 2008
splintellz1
  • 37 Answers
SOURCE: Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Posted on Jul 03, 2009
I was using my Ativa DX180D and it was working fine. It just stopped and there was no power. I have tried all the plugs in the house but still not coming on. The basket is on properly and you can hear the click of the switch when you plsce the top on the basket. Any suggestions?
Posted on Sep 01, 2009
  • 257 Answers
SOURCE: I need a fuse for our Ativa AT 1250 shredder ..
Read ITS RATING or remove it and buy from electronics shop.
Posted on Sep 25, 2009
SOURCE: Ativa X1000 paper shredder that doesn't turn on
took the shredder section apart, cleaned out the gears of paper and a broken mount (plastic piece), and hand turned the electric motor to free it up. After assembly, the ready light works and so does the FWD/REV directions for shredding.
Posted on Nov 10, 2009
Ativa Shredder says door is open but it is not. Therefore it is will not work.
Door switch sensor is defective or the wiring is damaged, check that.
Dec 01, 2017 | Shredder Office Equipment & Supplies
RED Light is on (left of the green light)
Reverse shredder and clean out as much paper shred as possible. Use some lube oil. Hairclipper oil and canola vegetable oil are good choices.
Aug 26, 2015 | Ativa MD1250 12-Sheet Cross-Cut Shredder -...
Ativa shredder manual
I could not find a manual or support on Ativa website but I searched their FAQ. It said that the shredder basket must be fully closed and integrated with the shredder. I had the same problem. I pushed the basket firmly into place and it stopped. I believe this flashing scheme may be telling you that the shredder and basket aren't properly aligned.
Oct 05, 2013 | Office Equipment & Supplies
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
DQ83M ATIVA SHREDDER ...LIGHT IS ON BUT DOES NOT SHREDD
The RUN green light is on but no motor is operating for any function of the Ativa DQ 83Mn Shredder. What can be inop?
Sep 17, 2010 | Office Depot Ativa DQ60M Shredder
I have an Ativa AT120DC. It won't operate
I have an Ativa AT120DC Shredder. When it is switched to auto there is dim green light and it doesn't start. If I feed paper in it makes no difference. For some time it always started up when you switched it to auto and didn't wait for paper to be fed through. If you remove the basket the Door Open light comes on. can you help?
Mar 18, 2010 | Office Equipment & Supplies
The shredder is showing that it needs oil, what type of oil is required on this shredder
you can buy oil at office max or staples or you can cheat and use sae 20 light gear oil , or pnumatic air tool oil from ace hardware
Jan 06, 2009 | Office Depot Ativa DQ60M Shredder
Ativa shredder xf50d not working light not coming on
If you don't have lights you probably have a blow fuse.
Aug 26, 2008 | Office Depot Ativa DQ60M Shredder
On the right side of the waste basket(as you face it) is a tab that pushes a button on the shredder when it is in place. The tab is not making contact with the button. Push the side of the basket where the tab is when you have paper to shred in it. If it begins to shred, you may have to bend the basket inward so that the tab makes contact. I have had this problem.
Aug 24, 2008 | Office Depot Ativa DQ60M Shredder
265 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
