Question about Whirlpool Duet GHW9150P Front Load Washer
Control panel lock unpluging and pressing the control
Control panel lock unplug and pressing the control unlock will not resolve problem
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this issue Press and hold the END OF CYCLE SIGNAL button for 10-15 seconds. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
I have a whilrpool frontloader and it is stuck on "control locked" how do I unlock it?
Look for the End of Cycle button on the control panel then press and hold it for 3 seconds or until the Control Locked indicator turns off. There's actually a marking under the button saying "Hold for 3 Seconds to Lock/Unlock Control". Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Mar 04, 2011 | Whirlpool Washing Machines
The panel says control locked and the machine will not do anything
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Jan 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How to unlock controled lock
You can try a hard reset.
Turn the machine off if you can
Unplug it from the wall outlet
Leave it for about a minute
Plug it back in.
Always use caution when working around electricity and a washing machine
Are there any lights showing on your machine? What is the make and model of our washer?
Dec 31, 2010 | Whirlpool Washing Machines
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to an electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The control lock button is light up and the washer won't work.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 23, 2010 | Whirlpool Washing Machines
How do i get the control lock button to turn off?
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
My washer has the control lock on how do I unlock it?
The Control Lock is unintentionally turned on. Press and hold the End of Cycle button until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control if the End of Cycle button does not unlock it. Replace the control if unplugging and the End of Cycle button fails to unlock it. The control can be locked by pressing and holding the same button until the Control Lock light turns on.
Oct 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Control door lock light stuck 'on'
Unplug it for 40 minutes to reset.
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Nov 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dacor ECS136 Control panel just beeps but does not work
i am having that problem with my maytag one. the only thing i can do is unplug it and quickly press bake and set the temp and time length. mine says its locked though. i am trying to figure out how to unlock mine.
Oct 30, 2008 | Dacor ECS136 Epicure Stainless Steel...
Whirlpool Duet GHW9150P Front Load Washer Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
