Question about Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE
No cooling in refrigerator compartment
Refrigerator is fairly new ... 5 - 6 yrs old ... it is in a home that was unoccupied/vacant for 3 years, but heated in winter. I recently bought the house and turned on the refrigerator and freezer (controls had been set at "- -". Freezer cools properly ... ice maker works fine ... all lights are on/OK, but no cooling in upper refrigerator. I tried unplugging the refrigerator then plugging it back in. No luck ... still no cooling up top.
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 1122 Answers
SOURCE: ice maker leaking into ice storage tray
disreguard all the other fixyas,first if you still have ice buildup get your hair dryer and heat it up and melt it,then remove the front off the icemaker,you have a cube size dial,turn it down and it will reduce the amount of water that goes into the icemaker,if that does no work go on ebay and pickup a univeral icemaker for around $50,hope this helped you-mike
Posted on Oct 25, 2008
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
rafaelrs38
  • 12 Answers
SOURCE: freezer and refrigerator stop cooling, back of
clean all the dust and form the gril on the back of your frig
Posted on Aug 10, 2009
imufo2
  • 3773 Answers
SOURCE: I have 'Magic Chef' 10.0 cu. ft. Refrigerator.
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 28, 2011
Why does my refrigerator circulate on bottom but not on top
Is this is a bottom mount fridge? Hey if your fridge is a fairly a new one. Say less than 8 years old and a fancy one then this is how it works.
a) Fan in freezer circulates air. Mainly to the freezer compartment.
b) Then for the fridge compartment there is a Vent door operated by a vent motor.
Either this vent motor not working and opening, or it is frozen or the thermister that controls the temperature on Fridge compartment is not asking for cooling and thus not sending power to the vent motor to open.
Sep 09, 2014 | Sub-Zero Refrigerators
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Refrigerator has been in stroage for 3 years. It is about 4 yrs old. Recently pulled from stge to use but it will not cool or freeze
The gas has leaked out. Please have it serviced through a service technician as the machine has been lying idle for 3 years.
Jul 01, 2010 | Refrigerators
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
I have an admiral refigerator (top freezer) less than 3 years old. The unit sat in a vacant house unplugged for about a year and now will not cool. Any suggestions
Good day,
Check in the freezer compartment to see if you can hear the fan motor running. They will freeze up if left off for extended periods of time.
Another fan motor on the bottom back near the compressor can suffer the same fate.
If both check O.K. Then since it's under 5 years you could have a refrigerant leak or a compressor problem that is under factory warranty.
Call your selling dealer for service.
Feb 05, 2010 | Maytag Admiral Top-Freezer Refrigerator
I am looking for a reliable refrigerator that will last for $3,000.00 or less. What brand(s) would you recommend?
I have had great service from my Hotpoints that are realy Ge. They Are made in, In. USA
I have 5 working know. 1 is 15 yrs, 3 that are 5 yrs old, And a 1 year old. I clean under them with a vacuum and a brush every Labor Day. Because its easy for me to keep track of it.
hope this helps you.
Sawdust
Aug 15, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
AMA BX21 7 years old Came home found freezer warm and thoughted, top referigator was still almost cold, have bben gone 5 days---the compressor keeps trying too start but cuts off after 30 seconds ,...
Look inside the fresh food compartment. Behind the temp. control cover is a defrost timer. Yours may have a small opening that you can put a pencil eraser in and turn clockwise. When you do that the refrigerator should begin cooling again. I will be here to help you get your refrigerator going with diagrams and part numbers, Thanks, Sea Breeze
Apr 20, 2009 | Amana ARB8057CSR Bottom Freezer...
My refrigerator does not cool properly. The freezer does not have ice built up and the fan is working, I can here it blowing when i open the freezer. The freezer almost works too well, it is at its lowest...
The lowest setting in the freezer compartment may be set to cold holding back cooling to the refrigerator. Try your settings at mid-point on both refrigerator and freezer settings.
Dec 05, 2007 | Kenmore 73503 Stainless Steel Bottom...
Amana 25" Cu Ft French Doors Bottom Freezer Refrigerator, AFD2535DE Logo
44 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
