Question about Gestetner A045 Wide Format Copier
Any RW-240 drivers available for Windows 7?
Recently upgraded some of the office computers to Windows 7, and haven't been able to get the RW-240 driver software to work. Any Ideas?
  • 2 more comments
  • wishnias Jun 02, 2010
    Trying to plot from AutoCAD 2011 LT to a Gestetner A045 wide format.
  • Leroy Elliott
    Leroy Elliott Jun 02, 2010
    Beats me, Google it
  • wishnias Jun 03, 2010
    Googling it is what led me here... I've been told that it's a dead official development branch, so I'm reaching out to communities to see if there's a workaround or anyone who's had a similar experience.
  • Anonymous Mar 31, 2014
    windows 7 winprint windows 7 DRIVe needed..?Tanks
    New Friend:
I know it is a bit late but my company had the same problem just a few weeks ago and I figured out a work around that might help.
First of all, we have a computer dedicated to our Savin 2400 that still runs XP. I found this
http://www.howtogeek.com/howto/33088/print-files-from-anywhere-via-any-device-with-dropbox/
which allows you to set up a dropbox and has a .vbs script that is set to auto print.
From there it was easy, just go out and download a pdf image writer like this one
http://www.pdfill.com/freewriter.html
or any other document writer and set the default folder it saves to in the dropbox print queue. This will let you hit print, select your document writer (which you can rename to "ricoh") and print away!
Posted on Feb 04, 2012
SOURCE:
Tip
Upgrading to Windows 7?
Many people are hurrying to upgrade their Windows XP or Vista computers to Windows 7.
My advice is simple. Do a little bit of research first to make sure your computer and other peripheral equipment, especially printers, have drivers available for the new operating system. There is no greater frustration when you think that you are making an improvement and your sound or your printer doesn't work after the upgrade.
Nearly all computer manufacturers have support sites where you can check to see if the drivers are indeed available. For example: If you have an HP or Compaq go to HP Support and enter your model number and follow the links to Software & Driver Downloads. Click on Windows 7 when you get the OS choices and it will let you know if drivers for that equipment are available.
I would also suggest that when you find the drivers for your computer and equipment, that you go ahead and download them to your computer and burn them all onto a CD/DVD so that when you do upgrade they will be right there at your fingertips and the process will go smoothly.
Happy Upgrading!
on Dec 04, 2009 | Computers & Internet
WHERE CAN I FIND ALL THE DRIVERS I NEED ONCE UPGRADED TO WIN 7 (32BIT)
Hi there!
Once Windows 7 is installed in the computer, you don't need to install all the drivers for the computer since Windows 7 can use the native drivers except for the webcam. I haven't found the one working for it.
If you insist on installing the drivers, you can download it: ASUS A8Js. It is the last one on the list. You'll have to install each driver manually since auto.exe will not work for Windows 7.
Hope this helps.
May 21, 2011 | ASUS A8Js Notebook
I need solution for this problem immediately I installed windows 7 in my PC. after that in My PC DVD RW is not working.
Was the Windows 7 installed from a clean slate or you upgraded from Vista to Windows 7? If you have upgraded from Vista to Windows 7, then this is definitely a driver problem. You can try to update the driver by going to Device Manager, check if the DVD drive is listed. Pull down the drop down list, and right click on the devices listed under DVD/CD-ROM Drives and choose Update Driver Software.
If the DVD drive came with a software bundle (e.g. Nero Burning Application) Try reinstalling these application under Windows 7 Environment.
Mar 26, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
Own a lexmark X7350 printer. Have Windows 7 OS. Downloaded the Vista driver for printer. Cannot scan a document. have to use Lexmark Photo Editor and scan as a black and white photo. This info was...
Lexmark X7350 support
Summary Use Vista Driver in Windows 7
Detail Driver Support
For many of our products, the Vista driver will work in the Windows 7 environment.
Driver Availability
The links below list products which have Windows 7 support.
Windows 7 Home Office and SMB Products (Inkjet and All-In-One)
Windows 7 Business Products (Laser)
Driver Delivery
Windows 7 Compatible Drivers are available from the following sources:
Download from support.lexmark.com
Recently released printers include Microsoft Windows 7 drivers on the Software and Documentation CD provided in the box with the printer
Many printer models have drivers included with the Windows Operating System or available through Windows Live Update
Feb 06, 2010 | Lexmark X7350 All-In-One Printer
Cannot install x125 on windows 7 in new hp computer
Driver Support
Lexmark is in the process of preparing for the launch of the new Microsoft Windows 7 operating system.
Driver Availability
In the weeks leading to consumer launch of Microsoft Windows 7, Lexmark will publish the type of support expected and the timeframe in which drivers will be available. Lexmark is currently finalizing Windows 7 support for a variety of its existing products. The list of products which will have Windows 7 support at launch is available in the links below. Windows 7 Business Products
Operating System Driver Support
Some printer models will have native easy-to-install printer drivers embedded in the operating system's driver library. Lexmark is providing a wide variety of printer drivers to be included with Microsoft Windows 7.
Driver Delivery
Drivers will be available for download from support.lexmark.com , and recently released printers may have the Microsoft Windows 7 driver available on the Software and Documentation CD provided in the box with the device, or a combination of both driver delivery methods will be available.
Future Products
Starting in 2010, all new products will ship with Windows 7 support.
Nov 09, 2009 | Lexmark X125 All-In-One InkJet Printer
Can't get my lexmark z1420 to work with windows 7. tells me to enable bi-directional communication. already downloaded the lexmark drivers for windows 7 but no difference.
Driver Support
Driver Availability
Driver Delivery
Future Products
Nov 09, 2009 | Lexmark Z1420 Printer
4,007 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
gggg
Adorjani Laszlo
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
