Question about Maytag MAH8700A Front Load Washer
Machine is vibrating out of control in spin cicle
  • peter2030 Jun 02, 2010
    I don't think this is the problem. I opened the back and topof the machine and I notices 3 weight balancers. On the right side on the rear there is none. Is this normal?
Some times the floor is not stable, I was told to place a sheet of 3/4 inch plyboard under the washer to stablize.
Posted on Jun 06, 2010
  • 159 Answers
Hello..the reason i believe that your machine is doing this is because the dampner plate at the bottom is worn.The dampner plate is like a cartlidge that the weight of the drum swivles back & forth on.it is made of white plastic.
Posted on Jun 02, 2010
  • chrizzoclark Jun 03, 2010
    Sorry i didn't realise it was a front loader you had.Have you ever washed shoes in it because the weight of the shoes can't evenly distribute around the drum & ive seen drums actually buckle under the weight,these machine get up to high speed rpm on spin,the weight of shoes siiting to one side of the drum at high speed rpm's increases 10 fold putting pressure on one side & it can snap the supporting armes that are bolted the the very back of the wash drum,you can't see them.open the door & lift the drum up & down,see if you can feel abnormal movement or hear crunching metal.rotate the drum a tiny bit more & keep doing this until you have done full revolution.Let me know how you go.
    Ive had a bit more of a think on this one & i'm thinking that maybe,just maybe the weights you are talking about could be loose,i seen this just the other day on an electrolux F/L.the thing was so noisy.ckeck the weights & tighten them up if they are loose.look for other weights around the drum,at the front of the tub as well near door seal.let me know!
My washer has a strong noise in the braket wen is in spin psae on cicle. I thin has the transmition broken.
check for wobble in spin tub only not main tub if so tub is rusted on centre post and can be replaced
big job
Jun 09, 2011 | Washing Machines
MY WASHER IS NOT DOING THE SPIN CICLE, DRAINS ALL THE WATER OK, PUMP IS FINE, JUST DOES NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | LG WFT1071TP Top Load Washer
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Jul 16, 2010 | Kenmore Washing Machines
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
Machine does not drain and spin at end of cicle It is a LG top loader washing machine model R852
Your motor clutch is bad. That controls on the motor along with the timer on a washer from going to spin or agitate.
Dec 05, 2009 | LG Washing Machines
In final spin cycle my washer sounds like a jet engine ready to
the lenth of duration in all cicles are controled by the timer that is the part that you turn clock wise. also need to check the belt adjustment. If is direct drive, then check the motor mount and berings
Aug 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't drain or spin out
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Dec 12, 2008 | Danby DWM99W Top Load Washer
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Maytag MAH8700A Front Load Washer Logo
96 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
