Question about Brother IntelliFAX 1840C Plain Paper Inkjet Fax
MY FAX 1840 -C WORKS WELL WITH ORDINARY PAPER BUT WHEN USING GLOSSY A4 PHOTOGRAPHIC PAPER IT CONTINUOUSLY JAMS .
  • fshana23 Jun 03, 2010
    Unlikely diagnosis as the same glossy paper works perfectly in my Canon printer .The fault is in the Brother printer .
  • 47 Answers
The glossy paper is slippery and so it causing the problem
Posted on Jun 02, 2010
Epson Photo PX710W Unable to print on photo glossy paper. Always a paper jam message. Will print fine on ordinary paper. (Will print 6x4 size on upper tray). Help!! Geraint.
Im having the same problem, will print on normal paper but when I try to print onto Glossy paper it comes up with paper jam,or paper not loaded properly is anyone else hjaving this problem? Please help!!
Caroline.
Aug 25, 2010 | Epson Office Equipment & Supplies
Paper jam
Unplug the printer from power for ten minutes.
Remove cartridges and put them back, open all doors and close them back.
Oct 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How do u put the print paper in facing up or facing down printer photosmart c4750
If ordinary paper it does not matter.If photo paper then put it in the feeder tray glossy side down and one sheet at a time as glossy paper tends to stick and causes paper jams.
May 04, 2010 | HP Office Equipment & Supplies
I put an a4 glossy paper in for aphoto, try and print from the laptop but does not work. if i use normal a4 paper it works?
You need to find out the spec on the A4 photo grade paper.
If the paper is to heavy, then it will not pick and feed properly. If the paper is to glossy, it could cause the paper to slip and smudge or blurry the image.
If the paper is made for a laser printer, the ink will be absorbed into the page.
Laser printers fuse (heat and pressure) the image onto the paper. Ink printers, however, require that the paper be able to absorb the ink into the paper.
Don
Mar 10, 2010 | Epson Stylus DX8400 All-In-One InkJet...
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
Not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Aug 06, 2009 | Brother DCP 130C All-In-One InkJet Printer
Paper jammed but no paper is jammed.
Sounds like something has fallen into the paper path. Use a flashlight and small mirror to look down the slot where the paper goes. You may have to use a straightened paper clip or the like to help remove the obstruction.
Jun 26, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Epson RX520 feed problem when using glossy photo paper
clean the rubber rollers that pull the paper. hoping it 2 work fine....
Jan 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Brother IntelliFAX 1840C Plain Paper Inkjet Fax Logo
50 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
