Question about Frigidaire FRT18P5A Top Freezer Refrigerator
FRIDGE NOT COLD, FREEZER COLD - Frigidaire FRT18P5A Top Freezer Refrigerator
  • 1,531 Answers
There may be a large amount of ice build up on the evaporator coils.you alos need to check and make sure that the evap fan is running in the freezer compartment.if you do not here the fan running when the ridge is in a cooling mode replace it. if there is alot of ice you may need to replace the defrost timer
Posted on Jun 02, 2010
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
Kelvinator fridge not cooling
Try defrosting the fridge. Check the cold plate at the back of the food compartment once the fridge has been defrosted and turned back on again. The cold plate in the freezer (around the walls) will be cold to touch as will the cold plate at the back of the fridge,
Oct 20, 2013 | Refrigerators
Fridge (KBRA22KLSS00) has lower freezer compartment. Fridge is running, & freezer is cold,however upper portion of fridge is not cold. Is there a fan or a control to bring the cold into the fridge...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 31, 2009 | Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Belling B160 Fridge is warm Freezer is cold
In fridge freezer where the fridge is under the freezer, the cold air falls down a channel from the freezer. I had a similar problem and it was a failed defrost thermostat. The evaporator in the back of the freezer was a solid lump of ice and wasn't allowing any cold air to drop into the fridge. The defrost thermostat was changed and then 30 minutes with a heat gun melted the ice. It was worked fine ever since. On a side by side fridge, there is a bypass from the freezer to the fridge. Either way, you need an engineer. You are not the only one to see this problem with that model. I see two in Google.
http://www.ukwhitegoods.co.uk/forumsphpbb3/belling-b160-fridge-freezer-t48629.html
Sep 19, 2017 | Refrigerators
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Frigidaire FRT18P5A Top Freezer Refrigerator Logo
143 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
