Question about Frigidaire FDF70S Dehumidifier
Runs, but does not remove any moisture
The FDL70S1 dehumidifier is 2 years old, worked fine last summer. Fired it up yesterday on Continuous and it is not removing any moisture at all. Temp in the room is within limits, When it is set for any specific humidity level, it reverts to 80% after a few seconds.
heatman101
  • 43501 Answers
SOURCE: the dehumidifier is running all the time but not
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 18, 2010
heatman101
  • 43501 Answers
SOURCE: dehumidifier runs(fan & compressor)but pulls
heatman101
Posted on Jun 18, 2010
SOURCE: Humidifier runs but water does not drip from
LOW ON FREON.
Posted on Aug 16, 2010
heatman101
  • 43501 Answers
SOURCE: LG LHD45EL Dehumidifier - The dehumidifier runs
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Posted on Jan 27, 2011
  • 4736 Answers
SOURCE: dehumidifier is running but not taking moisture
has the filter inside the unit been cleaned recently? If not, it's probably clogged and want accept the moisture.
Posted on Mar 04, 2011
I have a Danby dehumidifier model DDR6011R and it runs but I have yet to empty any water from it. I have used other dehumidifiers in the same area and they take out tons of water. What's the problem
1st ck your humidistat settings yes the fan can run but not the compressor to take water out
2nd ck your filters could they be blocked ?
and last but not least if the unit is more than a few years old its not as efficient as newer units and will take much longer to work consider an upgrade to a newer unit , also moisture levels in basements vary due to season , winter not as damp as summer so volume of water removed will change
use an external humidy gauge to verify it working correctly there not so expensive now and can be gotten most places that sell dehumidifyers 70 % rh is considered normal
Oct 18, 2014 | Dehumidifiers
I have a fdl70s1 and will only work in continuous mode.. Collects water fine but turns off when I adjust humidity setting
I appreciate your post, Lee Silvey!
I understand that your Frigidaire dehumidifier, FDL70S1, will only work in continuous mode. Sounds like you could have a possible issue with the sensor or control panel. Are you under warranty? I would advise you to speak with your manufacturer to see if any further resolution can be provided. -Matt
Oct 15, 2014 | Frigidaire 70-Pint Dehumidifier -...
Our DeLonghi condensation removal system no longer removes moisture; it appears to run fine; the lights indicate all systems are on. I have cleaned the filter; cleaned the tube; disconnected the tube; set...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Aug 28, 2011 | DeLonghi DH100P Dehumidifier
My dehumidifier is two years old and only used during the summer months. This season it is running but not removing moisture from the air...the collection bucket is completely dry. Help!
heatman101
Jun 06, 2011 | Haier 45-Pint Dehumidifier
I have West ponte Mdf 65 Ae BA8 dehumidifier 1 year old. Filter is clean. It worked last summer but now after the winter it is running fine but no water is comming in the bucket eventhough basement is...
You may have the humidity/moisture level set to high. Try lowering it to 35%. Or if you don't have a LED Screen on your unit, turn it to maximum.
In addition, most dehumidifiers don't work well if the air temperature is between 40 & 60 degrees F. Keep in mind, the temperature at floor level in a basement is colder that the air temperature at chest high level. Raising the unit up, off the floor on something sturdy enough to handle the weight (with a full tank of water) and the vibration, may help.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 03, 2011 | Dehumidifiers
I have a FDL70S1 dehumidifier that runs and runs but doesn't take out any moisture from the air. I have cleaned out the filter and front screens thoroughly but it still doesn't work. The unit...
heatman101
May 10, 2011 | Frigidaire FDL50R1 Dehumidifier
Our dehumidifier runs but it doesn't take any moisture from the air. It was working at the beginning of the Spring. I cleaned the filter. I also kept it clean last year. We just purchased it last Summer....
heatman101
Apr 18, 2011 | Dehumidifiers
Fan no compressor will run
I have AD75USTO. Whirlpool  was running yesterday. Today it sound like its starting but will not boot up fan will not kick on. Does it need resetting or what. Only a year old only used for one summer?
Feb 04, 2008 | Whirlpool AD40USR Dehumidifier
Frigidaire FDF70S Dehumidifier Logo
136 people viewed this question
Top Frigidaire Dehumidifiers Experts
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
richie46
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
