I have a 5-6 year old 5 cd changer and a cd is stuck in it and It will not open. I cut all power to it, but that did not work.There is no info in the manual regarding what to do if this problem occurs. I do not have the model number asw the unit is at my summer home.
  • 192 Answers
Is the unit a rotary feed (meaning its a round wheel with all disks on same level and when the tray opens it rotates to give access to teh disk) or cartridge type where you load the CD's into a cartridge and then teh cartridge into the player? If its a rotary type once the power is cut you can carefully pull the drawer out... Do it patiently and gentle...rush it or pull too hard and you will strip gears. POWER MUST BE OFF or the motors will resist and you will strip gears too. Once out you can reach teh CD. If its a cartridge type some support sites from manufactureres have an all eject process by pressing the power button and eject button at same time. If the disk is STUCK/Misfed and has caused a misalignment then none of the CD's would change and in that case you would have to determine if you want the CD player or CD more as you are going to have to dissasemble the player to access the disk.
Posted on Jun 02, 2010
2005 Chevy Malibu Maxx cd changer error
You will need to have the radio reset or checked out at the dealer.Ther could be a cd stuck in it.Or the radio/CD player may have be on when the battery power got to low.
Jan 10, 2010 | 2005 Chevrolet Malibu Maxx
Durabrand W600-S cd tray wont open
Hello, this kind of repair requires certain skils and knowledge about the cd changer mechanism. Please claim for an in warranty repair or replacement of the system. If you need more info please advice. Arpi
Jul 16, 2007 | Durabrand W600 Shelf System
6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
Sep 29, 2009 | Car Audio & Video
Sony chc cl 5 md - cd changer doesn't open
I had a similar problem with my sony cd changer. Took it apart it turned out to be the drive belt a 3 pound part. Got a new slightly smaller one and works well. Very easy to replace.
Jun 24, 2009 | Sony CHC-CL1 CD Shelf System
Disc stuck in cd changer
there is a large gear on the top of the cd mech, turn it counterclockwise to put the cd back in the magazine. the changer will probably work after that.
May 09, 2009 | Car Audio & Video
10 year old stereo system CD changer won't play discs
Dust may not be the entire cause, but without knowing the make and model, anything I list would be pure speculation. Please post the make and model. That should give me enough info to list the probable problems and their solutions.
Thanks,
Dan
Mar 17, 2009 | Audio Players & Recorders
How can I get the cd changer to stop changing non stop?
Something is out of timing. When powered up, the unit trys to get to a known state and will continue until it reaches that state. If the timing of the gears has been changed, this may not occur.
I'll try to see if I can create a set of instructions to re-time this.
Dan
Mar 11, 2009 | Sony MHC-GX450 CD Shelf System
STUCK Door
You will not get shocked if you stay away from the power supply, I have worked on several of these,the cd's are pilled up behind the door, remove the screws ,remove the cd's ,and hopefully you did not strip the cd turntable gear. You will know if you the gear is damaged, when you power the unit up after removing the cd's .the turn table assembly will rotate very jerky.or slow ,or It might not move at all..if so let me know i can help you with that..good luck
Nov 02, 2008 | Harman Kardon FL8350 5-Disc CD Changer
Wire diagram
You did not list the year of your vehicle.
This is where I find most of them.
http://www.the12volt.com/installbay/vehicles.html
Best of Luck.
Nov 16, 2007 | Jensen XCH6RF 6-Disc CD Changer
Pioneer cdx fm653 6 disk changer won't power up
first try to get another display, maybe it's broken (could be the cable cutted), the changer with a motor noise in the moment you plug it, tell me that its ok (95%).
Sep 12, 2007 | Pioneer CDX-FM653 6-Disc CD Changer
329 people viewed this question
 Grubhead
Grubhead
