Question about Kenmore Refrigerators
The divider between the two compartments of our model106.51564103 is very hot.
    President:
  • 949 Answers
This is caused by the condenser running hot due to being dirty or a fan failure, see the link below for instructions and details I put together for this issue. Let me know if it was helpful.
Hot Divider
Posted on Jun 02, 2010
Refrigerator quit working, power to compartment lights OK
If this is an American model refrigerator I will need to know the model number to see what may be happening. Can you post the model number? Thanks Sea Breeze1_10_2013_2_30_52_am.jpg
Jan 10, 2013 | Refrigerators
Divider between two compartments is hot model 106.59599990 side by side refrigerator
It is supposed to be hot. Approximately 110 degrees.
It prevents condensation between the doors.
The hot gas refrigerant line is routed through the conduit in between the doors.
It is OK.
Sep 06, 2010 | Refrigerators
Wall dividing fridge from freezer is very hot to the touch
You either have obstructed coils (lots o dust) under the fridge or the fan that is supposed to draw air across them has ceased to work. Check the coils and clean as necessary, and check the fan. Maybe you will get lucky and find something caught in it. If the fan is not working, leave the back cover off the fridge and put a small window or box fan back there until you can get the fan replaced. The fan will keep the fridge running for you in the meantime.
Jun 29, 2010 | Refrigerators
Divider between side by side compartments hot
The area arond where the seals is heated to stop the seal getting damp and mouldy.
Apr 17, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
Center divider between refrigerator and freezer where door seals rest is getting extremely hot.
check the fan in the machine compartment...if the fan is not turning when the compressor is running you have a bad fan motor. this caused the youder loop to over heat trying to cool the condencer...hope it helps
Sep 19, 2009 | Refrigerators
The dividing wall between the freezer compartment and refrigerator compartmant is very hot to the touch , use to be warm now almost to hot to touch. mod. #106.56539400
the condensor fan by the compressor is not running. this fan cools the compressor and condensor coils. if it does not run then the mullion (center between frzr and refrigerator side) gets very hot
Jun 24, 2009 | Refrigerators
KitchenAid ksss48qmb01- divider between the two compartments is very HOT
generally this problem is caused by the evaporator fan not running, check the evaporator fan motor for blockage and or failure.
May 19, 2009 | Refrigerators
Divider is hot
England,
No clarification necessary. The problem is most definitely the condenser motor. Here is a full diagram of the "unit compartment"... the part you're looking at is number 24. Maybe you have a local part house, if you do just call them and ask for a part number W10124096. Or you can plug that number into a search engine and go price shopping (there's a $10.50 price difference between Sears and RepairClinic, for instance)
Anyway, the repair is straight forward. Roll the fridge out and UNPLUG IT. Remove the lower rear panel to expose the unit compartment. Now all you have to do is use a 1/4" socket and remove the motor from its' bracket (just slip the fan blade off the end of the shaft). Your new motor comes with instructions... just follow them and button everything back up! It's a breeze. Total job time = ~ 30 minutes.
Please remember to rate this solution as "FixYa', OK? My "guru" rating is counting on you.
SG
Apr 21, 2009 | Kenmore 56539 / 56532 / 5653 / 656534 Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Roper side by side
clean the coils under the machine and make sure the airflow under the machine is not obstructed in any way. refrigerators release some of their heat between the doors to prevent condensation, but if it very hot then the machine is not releasing enough heat from its coils under the machine.
Jul 06, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
244 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
