Question about Cub Cadet Lawn Mower PTO Belt Replaces CUB CADET 75404064
Can you adjust the tension on the drive belt on a cub cadet lt 1045
  • 1111 Answers
SOURCE: Engine will not start
you have atleast 2 safety switches on there. one under the seat and one one the brake. if either one would fail, the engine will not turn over! i had to replace mine last yr
Posted on Jun 17, 2009
  • 12170 Answers
SOURCE: my cub cadet lt 1045 starter spins , but doesnt
try to lube under starter gear if still not moving need to have starter rebuilt or replaced
Posted on Oct 14, 2009
bbreton
  • 437 Answers
SOURCE: I have a cub cadet LT 1045 and every so often the
There are a few possibillites: a bearing is starting to go on the quill assembly or idler pulley; the PTO on the engine is heating up and quitting to work until it cools off; or you may have a switch going bad. I would look at this first.
HTH
Good Day
Posted on Nov 10, 2009
RonInFla
  • 86 Answers
SOURCE: Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Posted on Apr 10, 2010
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
I have a 2006 Cub cadet LT 1045. My model only has one idle pulley. I am having a hard time keeping belts on. Does anyone know a fix for this
have you got the belt on the right side of the idler pulley
the back of the belt should be running on the pulley
Sep 25, 2015 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Diagram for drive belt pulleys for cub cadet 1045
Round the two outer pulleys on the deck. Round the the outer pulley in middle deck, round idle pulley inside, next pulley in center of deck to drive pulley
May 03, 2012 | Garden
Cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
Apr 21, 2012 | Cub Cadet Garden
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Lawn Mower PTO Belt Replaces CUB CADET 75404064 Logo
517 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
