Question about Brother MFC 6490CW InkJet Printer
Trouble printing How to set printer to print on 11x17 ledger Paper?
  • 4,737 Answers
It'll be better for you to use the built-in A3 paper size, otherwise you'll not be able to print it perfectly. I you would like to do it, You can try this, after setting the documents and the documents size, give the print command, and under the printer properties, select the paper size, you'll see an option (custom) from the drop down list, select it an set the size, but you must leave a space for the printer to hold the paper. Good luck. Thanks for using FixYa.
Posted on Jun 02, 2010
11x17 paper isn't printing properly
Check your printer manual to see if there is special setting for the 11 X 17 paper that you are using. If printers are not set up properly you can have hassles under certain conditions.
Aug 27, 2015 | Office Equipment & Supplies
Printing 11x17
take the paper 11x17 paper out of the draw. or select different draw in the printer properties
Jan 30, 2014 | Konica Minolta Office Equipment & Supplies
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
I want to use 11x14 paper on my dj1280 but it is not in the menu. neither is there a provision for user-defined paper sizes. what to do?
The 1280 isn't compatible with 11x14 paper. You can either use legal size (8.5x14) or ledger size (11x17), but you can't customize it to use 11x14.
The best solution would be to print onto 11x17 paper and then cut it to 11x14.
Jan 14, 2010 | HP DeskJet 1280 InkJet Printer
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Can't print multiple PDF files in 11x17 format. I open windows explorer and select the specific PDF files. Click on File, Print. They all print out, but they all are 8 1/2 x 11 on a 11x17 paper, instead of...
Adobe Reader can be real pain it the... neck sometimes.
But first I would inspect not only the printer setup, but also printer's default print settings. Windows XP has 3 places, where you can see the printer options:
1. Printer properties
2. Print preferences
3. Default print setup.
The third one is the one you have to set. When you double click on your printer icon, a print queue window opens. Choose Printer->Properties, go to Advanced tab, and on the bottom there's a button "Default print setup" (I don't have English XP handy, so I'm translating back to English from my version - excuse me if they might appear a little different).
It's there you need to set up the default page size and so on.
If this still doesn't help, try opening Acrobat Reader, setting the Page Size Scaling to None, printing something and closing Acrobat Reader. From what I've seen, it tends to remember this setting from previous sessions.
You may also try alternative PDF readers, like Foxit Reader or PDF Xchange Reader.
Good luck :)
Oct 28, 2009 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
How to print 11 X 17 documents using a Kyocere CS 2550 printer
Use this method:
[File]
[Print]
Select the printer from the list and click on [Properties]
Change the "Original siae" to "11x17"
Change the Output size from "Same..." to "8.5x11" or "8.5x14"
[OK]
[OK]
Sep 29, 2009 | Kyocera CS-2550 Black and White Copier
Won't print ledger size
Are you loading the ledger in the right place main tray or by pass?
Printer properties set correctly?
Oct 10, 2007 | Minolta PageWorks 20 Laser Printer
Brother MFC 6490CW InkJet Printer Logo
332 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
