Question about Sharp AL-1655CS Copier
I have a Sharp AL 1655CS replaced toner & drum last week, cleaned glass & covers,vacummed old toner and copies a terrible..do I need a tech to diagnose and make the repair?
    President:
  • 3,085 Answers
I'm afraid you do.
Posted on Jun 02, 2010
I CHANGED THE TONER AND DRUM, WHERE ARE THE MIRRORS AND GLASS ON SHARP 1551-CS
Does this happen when you print!! Not copy. If it does when you print might check the transfer roller and or transfer & sep assemble across from the drum. If printing is OK then clean the glass on/inside the doc feeder you will see it follow the paper thur the doc feeder
Nov 21, 2015 | Sharp AL-1551CS Copier
I have a Sharp AL-1655CS and when i make copies, the copies are really dark. For example, the white areas come out gray and dark. How can I fix this problem?
I would try a different toner cartridge or possibly a drum cartridge. Have you had the machine serviced at all? When?
Feb 14, 2011 | Sharp AL-1655CS Laser Printer
I own a Sharp Al-1655CS about 2 yrs old, I have a problem, the balck toner powder is exiting the back of the machine and copies are very light. The copy count shows 12,000 copies made. I have repalced the...
These are very good machines so I would see no reason to replace it. Do you have the operators manual? If so look up the setting for "toner save mode" and make sure it is NOT turned on.
The drum unit is good for at least 18,000 pages so I would not suspect the drum. I even reset the counters on the drum units and can get up to 36,000 pages on them. Do you have the machine hooked to a PC for printing? If so is there any difference between printer density and copy density? If so then the issue is with the scanner density setting. If the copy and prints are both light then it is a print engine problem. If several toner cartridges are doing the same light print then I would suspect that your laser scanner optics are dirty. There is a narrow strip or slot just above the drum unit that the laser beam goes thru to write the image onto the drum. This should be cleaned and then the machine re-tested. If no improvement is see then the machine will have to be dis-assembled and cleaned which would require a compentant service technician.
Good Luck and Thank You for using Fixya.
Aug 14, 2010 | Sharp AL-1655CS Laser Printer
My Sharp AL-1655CS copier has new drum and toner. Leaves blank banding lines verticaly down the page in at least three areas.
This is a good one you may need to get it serviced.
The toner is held to the drum by static which rolls the toner onto the paper and seals the deal you may have a bunk drum, Validate your warranty and check for a service center.
Oct 19, 2009 | Sharp AL-1655CS Laser Printer
Sharp AL 1655CS Grayscale Copier prints with black lines
Lines on copies can come from the optict area, charge grid and comb or the fusing roller. Stop the copy halfway through the cycle and see where the line starts to appear. If you see it as much as you do the rest of the print, it is either optical or in the drum charge unit.
Jun 26, 2009 | Sharp AL-1655CS Copier
Sharp AL-800 light copies
Check the machine for a **** or dust glass above the drum.
Check and clean coronas, the wires and shells may be dirty reducing charge.
Run a few white copies, to check of the toner / carrier ratio is low.
Hope this is of some help.
Ed
May 11, 2009 | Sharp AL 800 Copier
AL-1642CS
try to clean the cover glass at the top of the copier with alchol.
be sure that ther is no any dot or lines on top of the glass specialy the right side.ok
Apr 16, 2008 | Sharp AL-1642CS Copier
Black lines running vertically through resulting copies
Clean the scanner glass. a small particle will cause this to happen.
Apr 07, 2008 | Sharp AL-1655CS Laser Printer
Leaves about a 1/4 inch space down middle of paper.
That is the cleaning assembly in the drum cartridge.Either something slipped into the cartridge or the blade tucked. Sounds more like something is in the cartridge blocking the drum from both cleaning and charging/
Mar 05, 2008 | Sharp AL 1631 Copier
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
Sharp AL-1655CS Copier Logo
106 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
