Question about Whirlpool GEQ9800P Electric Dryer
The dryer works but does not heat
I am willing to take a look, but am not sure how to get into it without damaging it.
How do I access underneath the tumbler in order to check out the parts with an electrical tester
  • Jamey Gremillion Jun 05, 2010
    Thanks for your help. I appreciate your help. I actually figured out the problem when I started taking a closer look at the power receptacle. I didn't see when I first looked that the receptacle looked a little contorted. There had evidently been a short, so I replaced receptacle, pigtail, and breaker as well. It is working fine now. JG
    President:
  • 1,554 Answers
The heating components can be accessed through the lower front access panel if the model number of the dryer is GEQ9800P; otherwise, indicate the exact model number for precise advice. The lower front access panel is attached to the front panel by two clips. Locate the clips into the seam between the front panel and the lower front access panel then insert and push a putty knife blade or similar tool to release and remove the lower front access panel.
Check the resistance of the heating element, the continuity of the high-limit thermostat and the thermal cut-off on the heater housing. Replace the thermal cut-off if it has failed (open) including the high-limit thermostat. Check also the continuity of the cycling thermostat on the blower.
Posted on Jun 02, 2010
  • Jamey Gremillion Jun 03, 2010
    Ok -- i figured out how to get into the thing. I tested all the things you suggested and even found in another place the suggested ohms that were supposed to register on the tester. The heat element registered within the parameters suggested. The thermal cut-off and its companion part were supposed to measure 0 ohms. They measured around .1 or .2. Is this close enough to 0 to be considered OK? My hunch is that these components are fine and the problem is upstream somewhere. But I am not sure. I would be very grateful to try whatever expertise you may suggest. Thank you -- JG
  • Jahn27
    Jahn27 Jun 04, 2010
    The high-limit thermostat and the thermal cutoff are apparently good. Check the continuity of the cycling thermostat on the blower housing. If it reads about zero ohms, start the dryer then check for for 120 VAC across each of the heating element terminals and the neutral/ground terminal or any unpainted part of the cabinet. Just make sure to set the volt-ohmmeter to 250 VAC scale or higher and take extra care not to short out the heating element terminals.
Dryer won't dry clothes in one cycle
Make sure a heating cycle is selected. Air and Fluff cycles do not use heat.
Make sure that both phases of 120 volt power are energized (total of 240 volts between the 2 phases).
Most likely the heating element is damaged, which usually means there is no heat at all. A dryer with 2 heating elements will have some heat, but not have enough, when 1 heating element stops working. A dryer with 1 heating element can partially fail and have partial heat, too.
Apr 03, 2017 | Dryers
Removing front panel on electric dryer model number 110.66732500
sure..you'll need to unplug the machine, tip it back a bit, and access those screws from underneath. Do NOT lay this unit on it's back. 45 degrees at most.
and by the way, put something underneath it while working on it.
Mar 09, 2008 | Dryers
My dryer is not heating. how do you access the ignitor and gas valve?
Remove the front access panel you should see the gas valve, ignitor and a flame sensor If any part of the burner assembly looks damaged then a malfunction will occur and this will be the cause of no heat
Sep 28, 2015 | Dryers
Not drying clothes
If you have an electric dryer the heating coil inside the dryer has a broken wire. The heating coil unit needs to be replaced. To change the heater you need to have access to the dryer from both sides without the electrical power connected. Some of the heaters are accessible from the front by removing the front panel of the dryer, some are accessible from the back. The service manual for the fryer will show the "exploded view" of the dryer this tells you which direction. If you are handy the replacement is not difficult. You will need some tools but nothing out or the ordinary..
Dec 09, 2011 | Fisher and Paykel Dryers
My electric dryer works but doesn't heat up. what could be the problem?
You probably need to clean out the exhaust, or, you have recently moved the dryer an the exhaust hose is kinked.
The dryer has an overload/overheat reset button underneath. I just posted the following for someone else:
You will need to take the front off of the dryer. On the top of the dryer, remove the two screw covers on the left and right side of the front under the dryer lid. Remove these screws and lift the top cowling up to see two more screws to remove so that the front of the dryer comes off. In the front, bottom, there is the red reset button. Once you know where it is, you can actually reach it from underneath the dryer without taking the front off.
Be sure to check that the exhaust is not blocked by lint, or that the flexible pipe is not kinked. These are commong reasons that the dryer has overheated. This reset button is your friend and it is telling you that there is danger somewhere. Try to find the cause to prevent an accident.
Sep 24, 2011 | Fisher and Paykel DEGX1 Electric Dryer
I have an LG DLE2532W dryer. It suddenly stopped putting out heat. I've heard that there's a heat regulator switch that can trip if the unit overheats located underneath the barrel. What's the easiest...
You r correct. Take top off. Take control unit off. Take front off. Search how to videos online, YouTube, repairclinic.com, appliancepartspros.com
Jun 05, 2017 | LG DLE2532W Electric Dryer
Whirlpool comercial quality super capacity dryer does not heat up? I have looked at the heating element and it does not show any signs of damage or overheating. What else should I look for?
visual inspection can be decieving, if you have access to the heater ohm it out
check it for continuity,
its really the only test that is foolproof.
if that passes, i would make sure you have proper voltage at the posts.
Oct 05, 2009 | Whirlpool LER4634J Electric Dryer
Not heating
I had the same problem on Frigidaire and Maytag electric dryers, with manual, not digital controls, and it turned out to be a bad electrical connection (i.e., one of the three wires from the power cord where it connected to the back of the dryer had come lose and shorted out). Be sure to unplug the dryer then check the power cord plug and connections, which should be easily accessible at the back of the unit on the upper left (you will have to remove the protective cover plate(s), which is held on by a screw). This would also be a good time to see if the circuit breaker has been tripped, which would indicate a short somewhere. If it has, I would move it to the off position until you've checked the electrical connections on the dryer. The heating element runs on 220 volts while the motor and everything else runs on 110 volts, which indicates a bad connection for the 220/240 circuit. You may need a replacement power cord if it's damaged (available at local hardware stores, just make sure it's for a dryer; they're different than other appliances) and/or a new connecting block, if it's damaged (you will likely have to order this part). You also may need new connecting hardware, so check to make sure the existing nuts are reusable. It's a simple fix that doesn't take much skill, just be sure to unplug the unit before doing any work, replace the connections exactly as on the original, and don't forget to reset the breaker if it was tripped or you switched it off. If that doesn't fix it, it may be the heating element, which is a whole other story. Good luck.
Jan 06, 2009 | Frigidaire FDE336RE Dryer
Dryer won't stay heated
check for broken wiring that could be touching the drum cant be sure without being there and checking it out
Aug 09, 2007 | Asko T701 Electric Dryer
Whirlpool GEQ9800P Electric Dryer Logo
51 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
