Question about Onkyo TX-SR705 Receiver
No sound! The receiver onkyo TX-sr705 does not have any sound coming out of speakers. Although, I can use the test signal, in setup, to set speaker levels but no sound from any input(s) whatsoever (even radio). I found the Service manual on line and tried some things and may have narrowed it down to two cards(all fuses are good). Still unsure and I cannot seem to locate any of the boards on line or locally. Any suggestions? Thanks for your time.
  • z_e_r_o_z_e_ Jun 02, 2010
    Thanks for you timely response!
  • 503 Answers
Did the speaker cailibration work on the speakers in question?
If YES, then the program material or settings you're using don't require the rear speakers.
By "Back" do we mean Surround or Surround Back? Surround Back speakers are the 6th and 7th channels in the 7.1 matrix. Not all source material has programming for them. But when using any 7.1 digital surround mode you can get anything, even stereo recordings, to output something from every speaker.
If NO, check your connections...
http://63.148.251.135/redirect_service.cfm?type=QuickHookup&file=TXSR805_QSS_En_0330.pdf
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Jun 02, 2010
    I was not getting any sound out any speakers. I have had this receiver for almost three years w/ no problems. I am running 5.1 on the 7.1 reciever so I am using Surr terminals for 5.1 instead of Surr back terminals for 7.1. I just tried the thermal sensor reset for the seems like 100th time and for whatever reason I now have sound once again. I am sure whatever is going on will return. I am guessing the thermal card is going out slowly. I am sorry I bothered you w/ my question please have a great day and keep on keepin' on!
How do I connect my onkyo tx-sr705 to a pyle pro speaker selector? I am "not" using the onkyo for a surround sound, only for music with 3 pairs of speakers in different rooms. (CD, Sirrus...
Hi Mdensonjr, I see that this was posted in 2011 but well the speaker selector would be connected to the Front speaker terminals, Thanks, JT
May 29, 2011 | Onkyo TX-SR705 Receiver
We wired our new home to have outdoor speakers and also speakers to our pool room. Before putting the receiver back into place after wiring the back, we quickly touched a speaker's wires to the wires...
It's not really clear if all of this is Zone 2 or not, or if you intend a second program to play in Zone 2.
If your Zone 2 is to a powered amplifier and its speakers the Zone 2 output would be FIXED (not variable from the host TX-SR705), that is, at a level that the receiving amplifier would control.
Page 99 deals with it.
Having just passive speakers in Zone 2 requires you to set Zone 2 to "ACT(ive)".
Mar 27, 2011 | Onkyo TX-SR705 Receiver
Connect an amp to a Onkyo tx-904
tou may want to hook this to speaker select switch
Aug 28, 2009 | Onkyo TX-SR705 Receiver
Onkyo 6.1 surround
Check the settings on your cable box for "Audio" settings and check the output. Should be set to "Dolby Digital" If you need more help, post a comment with the make and model of your cable box and I can walk you thru setup. Hope this helps
Jun 29, 2009 | Onkyo TX-SR605 Receiver
How do I connect my outside speakers to play?
The onkyo should still have a speaker A/B selector in the menu.
Check on the back panel for speaker A/B.
If it has or you decide to use Zone 2 you will need to set the sound programme to "stereo" so the rears and centre do not work.
You can still use a digital source.
You should be able to display the amp's menu on the screen.
Hook up "monitor out" (Yellow) via RCA connector to one of the "A/V inputs" (yellow) on the tv, this will show you a display of the menu and will make it eaiser to navigate.
Jun 16, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 - No Audio - Flashing HDMI
The posabilities is power amplifier on your reciever is bad,
replays reciever or repair it.More likely this is IC amplifier located on the main board of the reciever
Apr 15, 2009 | Onkyo TX-SR705 Receiver
The output to the front left channel is low
Try adjusting level calibration for the front left speaker under setup. This should solve your problem.
Mar 11, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 Muting Problem
if what Dark_Orbit said does not work try doing a master reset by ressing and holding the dvr/vcr button and stand by button simultaneously. This would erase all your assignments so you would need to reassign all your sources hooked up to your onkyo.
Mar 04, 2009 | Onkyo TX-SR705 Receiver
Onkyo TX-SR705 Receiver Logo
131 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
