Question about BenQ FP731 17" LCD Monitor
Just a little help..
Hi
I have the same problem as described in this topic just with a different BenQ model FP767. Do you think it would be the same solution? I have taken it apart and found all four transistors but I don't know how to check if they are shorted. Can you help please?
  • smokisa Apr 17, 2008
    Right, I have done as I was told... and I didn't find any blown.
    I mean if they are on the board and I put my multimeter on continuity it does make sound on all combinations but the values are different... and are all the same on all 4! So I took them off and redone as you told me... and it all seems ok!
    I have checked 2 diods that I read about in I think one of your other posts and they didn't look right as one of them had same values on the diod test on the multimeter bouth ways. This was with the 4 tranzistors on the board.
    But after I resoldered tranzistors back on to the board after I checked them the diod that had bad values is now the same as the other one.
    Do you think that all it needed is a resolder? I read they get hot and that's what couses dry contact.
    If not what to check next?
    Your effort is much apprechieted by the way :) so just keep on helping if you can... I have another 2 monitors with the same problem... All came out of one of our IT classrooms.
  • 472 Answers
Use a multimeter and follow this =) The dots will be the pins (just for reference)
  • PIN1
  • PIN2
  • PIN3
OK, it does not matter what outside one you would like to call pin 1 or pin3..so do not be too concerned with that.
Set the multimeter to continuity mode. (gives a tone when the 2 probes are touched together)
Put a probe onto one of the outside pins and use that as a reference to being pin 1, then put the other probe to pin 2
The move the probe on pin 1 to pin 3.
so if you touch them like this:
1 & 2
1 & 3
2 & 3
If any of those give a solid tone, then it is shorted. But you will notice there are 2 of these at the top of the board, and 2 at the bottom. If one of either is shorted, then they both need to be replaced.
If you follow that you will soon see if anything there is shorted. The biggest problem is this is only the beginning.
Hope it helps =)
Posted on Apr 12, 2008
  • Peter Thompson
    Peter Thompson Apr 17, 2008
    Sounds like your in for some fun. +)
    Check the PF link at PF801 (with the power socket at the bottom, it's near the top, close to the middle.
    It should hold a tone for 10 seconds + if it gives a tone, it will cut out after a few seconds if it's bad.
    If you were getting tones (solid tones) on the transistors, then they are indeed faulty. You should hold it on each grouping for 2 seconds to give the meter a bit of time to settle.
    Resoldering these has no effect. They get hot, but you need temps around 300 degrees to melt solder. They burn up after about 80 degrees in normal use.
    Take a photo of the top (component) and bottom (solder) sides of your board and email them to me. I will do a little coulouring in and send them back for you.
    mailto.saitek@tpg.com.au
My BenQ FP767 monitor power is on, but the screen is black. my pc is very good.
open back cover of your monitor then adjust the screen control of the flyback to your desired brightness
Joel
Apr 20, 2013 | BenQ FP767 17" LCD Monitor
The color on my beige BENQ FP767 is blue i cannot fix the color schematics back to the default settings, please help
Blue cast on the screen? Then check all the pins on both ends of the video cable, try it on another PC to make sure it is not video card problems.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 22, 2010 | BenQ FP767 17" LCD Monitor
FP767-v2 - 17" LCD Monitor: when you turn it on benq flashes on the screen...
Check the cable on your monitor through video card if there is loose connection. Check also the video card by replacing it with your extra video card if you have. I think the problem is not the monitor but the video card.
May 18, 2010 | BenQ FP767-v2 - 17" LCD Monitor
Benq monitor
Try checking the cables and disconnect all cables from system and monitor and reconnect all of them.
And in case it does not work,Please change the cable coming from tower to the Monitor as it seems that it has gone bad.
Hope this Help.
Cheers!!!!
Jul 22, 2009 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" Problem: Monitor wont turn on
Check four 5707, two 9204, and one bel 3A slow blow fuse. Also re-solder all cap and transformer.It's quiet common on benq and Dell(benq OEM) 17 LCD. For detail google "benq 5707", sure you can found. Good luck
Jul 07, 2008 | BenQ FP767 17" LCD Monitor
How to get audio from a benq fp767 lcd monitor
You have to plug the audio wire from the monitor into your speaker jack on your computer.
Jun 13, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 17" LCD Monitor Problem
IT seems you are not technically trained in electronics.In this case it's difficult to explain via this board,Best you find someone to fix it for you,you can try contacting Benq Support locally.
Sorry for not being able to help.
Samir
Jun 07, 2008 | BenQ FP767 17" LCD Monitor
BenQ FP767 contrast keeps appearing
The problem is with front panel switches.The contacts maybe leaky.You need to replace all the six switches.
Samir
May 21, 2008 | BenQ FP767 17" LCD Monitor
Benq fp767 backlight problem
I've repaired my FP767 just today. It had similar problem.
First of all I thought that I needed to replace CCFL tubes.
Then I noticed inflated capacitors in power supply.
I replaced them all and monitor works as new.
Apr 24, 2008 | BenQ T701 TFT 17" LCD Monitor
BenQ FP767 17" Power but no display?
Different faults here.
First fault is no power, it is bad capacitors on the power board.
Second & third faults are the inverters. (power but no image visible, but feint if you shine a light into the screen)
Check the 4 transistors on the main power board for shorts.
If you are unsure what that means, then take it to your local TV technician, he should be able to solve it fairly cheaply.
Hope that helps.
Oct 11, 2006 | BenQ FP767 17" LCD Monitor
BenQ FP731 17" LCD Monitor Logo
37 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
