Question about Refrigerators
Electrolux commercial fridge with bad noise now ice
We have electrolux commercial fridge with a problem. Started 4 days ago with a bad rattling noise. Traced it back to the evaporator fan inside. Then yesterday evening,the noise stopped so we left it. This morining, There was a large amount of ice buildup in the evaporator housing the and the fan no longer rotates properly if at all. What should we do?
  • ho_daniel Jun 02, 2010
    Thanks. I try the solution.
    Habit-Forming:
  • 193 Answers
Easy replace it bearings have failed
Posted on Jun 02, 2010
Side by side Electrolux. Water stopped working a few months ago. Tonight the freezer (sounds like the ice maker) started a very load humming noise that I can't seem to stop unless I unplug the fridge.
Refrigerator model number is? Could be a fan that needs replace soon to prevent damage to the evaporator should it start wobbling and hit the evap coil
Appliance 911 Sea Breeze
Nov 25, 2015 | Refrigerators
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Ice Melting towards the front of the ice hopper
Check that the fan motor wiring has not been disturbed. If the freezer fan is not working, the fridge will generally start cooling but due to poor air circulation , it will stay colder at the back but will get warmer at the front hence causing the ice to melt. The usual temp for a food compartment is around 4 degrees. The freezer should be -18 degrees celcius.
Nov 25, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Squealing sound when making ice
most of the time it is the water pump is going bad. It squeals real loud.
Sep 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Ice formation. double door electrolux fridge. not cooling
If there is ice built up on the inside back wall of the freezer, you have a defrost problem. Take the panel off, use a hair dryer to defrost. If you know how to use a meter you can check the heater and termination thermostat. One is most likely bad. If you cant use a meter. Put panel back on and plug fridge back in. It will work fine for around three days. This will give you time to get the part or someone out to fix and you will not loose your food.
Please rate solution
Aug 27, 2009 | Electrolux Refrigerators
Acquired second hand electrolux er3167bn fridge freeze. worked ok for about 10 days then fridge started to get warm, eventually ended up room temp. engineer said to switch off fridge freeze and leave for...
yep sounds as though it is iceing up after it runs for a couple of days
you may have a defrost heater or defrost timer not working
the fact it didnot have water in the tray, you prob have a blocked drain as well
May 02, 2009 | Electrolux ER3167BN Bottom Freezer...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
