Can a sharp lc37sb24u lcd fit on a 37" Vizio VW37LHDTV40A 720p Widescreen LCD HDTV - 16:9 5500:1 (Dynamic) 5ms 2 HDMI ATSC/QAM/NTSC Tuners (Black) My sharp tv is broken green light and I have a vizio with a screen crack. Is it possible to put the vizio parts on the sharp lcd?
  • 10,594 Answers
Both are different brand tv and internal circuit boards are not compatible to swap.
I'm afraid, both tv boards can not be exchanged.
Hope these info will help you.
Thanks.
Posted on Jun 02, 2010
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
My tv won't power up I go to turn it on but it shuts right off. What can I do to fix this problem
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 08, 2015 | Westinghouse 32" LD-3260 720p Widescreen...
Vizio 42" E421VO 1080p Widescreen LCD only shows 480p why
In order to help you out with this, I would need to know which input you are attempting to use, what the source content is and what kind of cable(s) you have hooked up to the target input.
Apr 28, 2014 | Vizio 42" E421VO 1080p Widescreen LCD HDTV...
Vizio e420vl screen whitish gray with black line, please help :(
mine did this I was told to pull out he plug and let it sit for about 20 minutes then plug it in. Hold the power button in for about 12 seconds to reset the television. worked good. oh keep your television away from AC s open windows. moisture can kill any electronics with just a few minutes of damp air.
Apr 21, 2014 | Vizio 42" E420VL 1080p 120Hz Widescreen...
Update firmware
Some gadgets get information overload if it can't retrieve the data fast enough to keep up with the movie. Get a faster usb, though it depends on how fast that gadget can read usbs.
Nov 01, 2013 | Samsung 23" T23A350 1080p Widescreen Led...
L19w89v desblock funcion operation
Your problem post is very difficult to understand, and have no details about the fault you experiences with this TV. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 10, 2013 | AOC 19" Envision L19W89V 720p Widescreen...
Flickering screen
Change the refresh rate to 60 hertz and try .
Oct 20, 2012 | Samsung 40" LN40C550 1080p Widescreen LCD...
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Is the Sharp LC32D47UT 32-Inch LCD HDTV suitable for use in Australia
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. The LC-32D47UT features a high contrast ratio, 6ms response time and wide viewing angles. The LC-32D47UT includes built-in ATSC/QAM/NTSC tuners, 3 HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input for PC compatibility. The LC-32D47UT features a black cabinet, and the included table stand easily removes for wall mounting applications.
Features
  • True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
  • Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
  • High Brightness - Sharp LCD TVs are very bright, so you can put them virtually anywhere - even near windows, doors or other light sources - and the picture is still vivid.
Jan 08, 2011 | Sharp 19 in. LCD HDTV
Es de 1080p o de cuanto
Product Description 37" HDTV, LCD Widesreen, 1366 x 768 resolution, 720P, Integreated ATSC tuner, HDMI, 2 HD component and 2 S-VHS inputs, 3D combi filter, Delivers Crisp Sharp High Definition picture quality, built in speakers for high quality audio sound. ES DE 720P
Dec 14, 2009 | Toymax Magnavox 37MF231D 37 in. LCD TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
