Question about One For All URC-3021 Remote Control
Need code for shrp tv
Need code for sharp tv, and also the remote have not a boton for code search..........
  • 2,335 Answers
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Sharp TV's 0093.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
Find instructions here for the One For All URC-3021 Code Search.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
Posted on Jun 16, 2010
I need the code to use on my universal remote for sharp Lc32Pd5X TV
Use code search to find something that will work. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jul 29, 2016 | Sharp Televison & Video
I have a Sharp 32 inch tv and an GE Universal remote needing a code to set...yr of TV not known
1392,1330,1326. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 29, 2015 | GE Televison & Video
What is the code for a sharp tv with a urc 7510 remote please, thanx
If your remote is programmable, you can use its code search feature to find a code for your Sharp TV. If a search through all codes stored in the remote does not work, you may have to try another programmable remote.
Mar 01, 2015 | Sharp Televison & Video
I need tv code for allforone remote for sharp tv
Three digit universal remote codes for Sharp TV are:
004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Four digit codes and synchronising procedure are given in detail in this site. "Electro-help". Type in this site name either to Google or Yahoo Search Box [not to the address bar to your browser]; and click search. You can see the site with same name. Check in and pull up older posts there.There are more than 225 posts, and all are about electronic equipments' repair help. Sometimes the ads beside the post will give you more details.
May 23, 2012 | Televison & Video
Tengo una television sharp y no se como programarle el control universal dish podrias ayudarme con los codigos y la manera en la que se programa
Hola mi nombre es Kimberly Escobar con DISH Network. Seria un placer ayudarle proveyendole la informacion que necesita para programar su control con su televisor Sharp. hay ciertos codigos que se pueden integrar a su control permitiendole funcionar con la T.V. Para la marca Sharp tenemos los codigos 628,739,741,605, y 835. El procedimiento es el siguiente: oprima el boton de T.V localisado en la parte de arriba en el control hasta que los demas botones se prendan en rojo una vez esten iluminados ingrese uno de los codigos seguido por el signo de numero, (por ejemplo 659#) el boton de T.V debe iluminarce 3 veces. Despues de esto puede intentar usar su control tambien puede entrar a nuestro link aqui puede encontrar mas codigos e instrucciones a como programar el control http://www.dishnetwork.com/SupportSection/remote-setup si necesita mas ayuda o tiene preguntas adicionales por favor contactenos directamente al 1800-333-DISH. Gracias y espero esto le sirva de ayuda.
Apr 04, 2011 | DISH Network IR Remote Control
What remote code is used with RCA remote for a
why dont you use rca's code search feature,Hold code search button untill lighted,press tv button on remote,then slowly momentorally press the power button on remote untill tv goes off,then press enter right after the tv goes off,there are abouy 200 codes on the rca remote control,so be patient.
Nov 24, 2009 | Sharp Televison & Video
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
Need codes for Sharp Tv. I have an older
URC-3220 One for All Big Easy 3 Universal Remote
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Sharp TV.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Mar 08, 2009 | LGDVB418 DVD Player
I need the code for my sharp tv so i can program my rca remote co
After much searching I finally found the code list for RCR451 Universal Remote. Here are the codes for Sharp TV. 1004, 1007, 1009, 1023, 1078, 1083, 1094, 1107, 1123, 1125, 1195
Jan 13, 2009 | RCA Universal Remote Control
Rca remote, codes don't work for sylvania tv
Trata con esto.
Presiona el boton Code search y mantanlo asi hasta que el led se quede encendido suelta y presiona el boton TV despues vas a presionar y soltar el boton Power hasta que el televisor se apague despues presionas el boton enter y el codigo queda almacenado.
El Tv tiene que encenderse primero manualmente.
Jun 03, 2008 | Sylvania 6420FB 20" TV
One For All URC-3021 Remote Control Logo
199 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
