Question about Garden
We have a sprinkler system with zone one not working. Any advice on how to get that up and running? All of the other zones work fine. Thanks.
  • tgpettit Jun 02, 2010
    Thanks for your help!
    Genius:
  • 1,040 Answers
Dear Tgpettit,
more than likely a bad solenoid or valve.
maybe a bad wiring connection.
you should have a white wire (common)
and a lead wire for each different zone (say you have four zones, you will have 4 lead wires)
get some 1.5 amp fuses from any local hardware store.
un hook the timer's transformer wires and be careful not to touch them together or you will fry the transformer.
touch one end of the transformer wire to the common,
and the other transformer wire to the lead wires one at a timewith a fuse in between the lead and the transformer wires.
when you are doing this you are simply bypassing the timer.
the good zones should come on when you touch their wires to the power.
when the fuse blows.. you know which valve has a problem.
more than likely you have a bad solenoid.
they get hit by lightening pretty often.
if you know where the valves are in your yard you can fix it yourself by checking for power at the valve or valves that are blowing fuses.
if you get power but no water. replace the solenoid. if still no go, replace the valve top too.
if you do not know where the valves are you should calla professional company in.
check for a leak on the fourth zone. a leak will sometimes cause an entire zone to not work.
but, always start at your timer when troubleshooting.
hope this helps
http://sprinkler-help.blogspot.com/2007/05/one-sprinkler-zone-not-working_26.html
Posted on Jun 02, 2010
    Is it too hard on our own to figure out where the valve is? Is that why you say we should hire a professional? Any thoughts, on how to find out where that valve is on our own? Thanks.
  • Yogesh Kshatriya Jun 02, 2010
    best way is to contact your manufacturer......... or looks for service manual or owners manual if any....
Rainbird troubleshooting
Check to see if the wiring is crossed.
Jul 18, 2014 | Rainbird Rain Bird Esp-lx 4-station...
I have a Toro 240-06-04 which is almost identical to the 250. My sprinkler system on the number one valve quit working. I thought maybe it might be a solenoid, so I replaced that and it still didn't w
Connect the wire form a working zone to the valve to zone 1. If the zone comes on you have short in the wire for zone 1. You can confirm this by connecting it to the valve that was working and it probably will not. If you have a spare wire connect it to zone 1 and in pin 1 at
the timer.
If valve still does not open and you replaced the solenoid (which is rarely the problem) the hydraulics are probably worn out in the valve. Purchase the same valve and switch out everything accept the valve body itself essentially rebuilding the valve.
Bad wire, no spare and you want to avoid running a new stretch. Merge this zone with a similar one by connecting both valves to 1 wire. If the pressure is good they should all work as 1 zone. Otherwise you will have to run a new stretch.
Apr 21, 2014 | Toro 250-06-04 1 in. FPT Electric Valve...
One zone has low pressure
Try getting information from the manufacturer.
Apr 12, 2014 | Garden
Sprinkler will not change zones
You mean timer will not change zones? Is it from zone 1 to zone 2? Does the timer say it is watering zone 2 and no water, does it default and shut down on zone 2? Does zone 2 have run time? Can you be a little more specific?
Feb 19, 2014 | Fimco 1-1/2 in. 10 psi 6 Outlet Indexing...
On auto mode sprinkler start sometimes out of the time zone
Maybe the trippers are worn out??
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Add a comment and give model number of product, and say if this is new installation or older installation that stopped working recently.
May 05, 2013 | Intermatic T8845PV - Sprinkler-Irrigation...
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
Sprinkler head does not spray water
Make sure when you pull the head to ck the screen you turn the system on and blow out the line, then run a hose through the head to make sure it isn't plugged up anyway. Depending on the head and the cost of a new one will dictate cleaning or replacement.
Oct 04, 2009 | Garden
Sprinkler control box appears fine, but sprinklers to not open
If all zones do not open, I would check the water supply first. Verify that the water is indeed on. If you have water at each valve location, then I would check at the wiring at the controller. Use a Multi-meter & check the resistance (ohms) between the common wire terminal and the wires at the terminal for zones 1 through 6. If you get an open loop (O.L.) reading on all zones, I would think the common wire is cut or disconnected. Also look for a rain sensor that could be wired into the common wire. If it is faulty or stuck, it could cause an O.L. in the wiring. If a rain sensor is wired in at the controller, disconnect it from the common wire path and connect the common wire directly back to the common terminal. If it works now, then you have a bad rain sensor.
A normal reading should be 20 – 60 Ohms from the common terminal to any zone wire. If you are in that range, the only other thing it can be is the output voltage from the controller to the valves. Use a Multi-meter & check the voltage at 24VAC terminals where the external transformer is connected. You should have 24-30VAC. Next, open zone 1 and check the voltage between the common wire terminal and the terminal for zone 1. You should have the same reading as you got for the transformer. If you have nothing or a large difference, then I would suspect the controller might be damaged.
Remove the power & 3 volt lithium battery and wait 2-3 minutes, then reprogram the controller and try again. Good luck!
Jul 27, 2009 | Hardware & Accessories
Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Jun 16, 2009 | Orbit Sprinkler System Power Source...
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
