Question about Brother HL 2700CN Laser Printer
Jamming The printer is jamming each print, it doesnt seem to be feeding the paper through, I am using the same 80g paper I have always used. It doesnt seem to have a problem when I use 100g paper but this isnt always practical.
Have you tried cleaning the paper pickup and registration rollers? See page 128 in the HL-2700CN User Guide available from the Brother Solutions Center
Posted on Jun 21, 2010
Says a front paper jam but no paper jammed any where
Your paper feder belt has ink on it and will not feed the paper. Remove the rubber belt and clean it good and clean and use compressed air on the printer tray area. If this does not work open the front feeder tray and set your computer to print from it. After about 500 copys it will normally have c leaned itself and be ready to feed from the main roller.
Feb 14, 2010 | OKI C5500n Printer
Canon MX310 keeps not printing and message comes up paper jam sometimes nothing happens sometimes startes to take paper then stops sometimes just feeds through without printing , there seems to be no real...
Have you ever tried printing sticky labels in the thing? You have to be careful with those because sometimes a piece will come off and stick in the corner of your printer. If you don't have long surgical tweezers to pull it out, you could be looking at an expensive repair. Also check your manual. There are two places the paper can jam in. You might have checked only one. I have a different Canon model but on mine I also have to make sure the correct light is on. Is the light for feeding from the back on, or the light from feeding on the front? If you have the same light, press it again to change the place where it will feed from.
Make sure your paper isn't curled or that you're using paper that's too thick also.
Can't answer more because I don't know what program you are using to try to print.
Sep 24, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper won't feed into printer. Always gets jammed
you must have objects foriegn objects inside your printer. i.e. paper clip or some other object . Get your printer and move it side to side see if you can here anything moving about. once its out then perform alignment of rollers using epson maintenance menu.
Jul 19, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Paper does not feed - GRABS RIGHT SIDE
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
Aug 03, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed correctly, keeps jamming up.
There IS something stuck in the feed path. If the paper starts to feed and then crinkles on the feed side, there is an object stopping the paper moving forward.
Lay the machine on it's back and take a sheet of very stiff card (A5 size approx) and push it through the paper path in reverse. So start where the paper would normally exit and push the card in. You may need to lift the pinch rollers just behind the print head by hand to aid the card through. Keep the card to the side that would normally crinkle but beware of the paper sensor flag. If you force it you could break it off.
Once you get past the pinch rollers behind the print head, push a little further then start to move the card in and out but along the length of the rollers. You should find that sufficient to push out whatever is in the path and having the machine on it's back will help it fall clear of the feed mechanism.
If it does not fall out using this method you will have to remove the covers and try to remove the ASF to get at the object.
Oct 14, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Brother HL 2700CN Laser Printer Logo
423 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
