Question about Dell 1320c Laser Printer
When we are printing the printer will not print the right color
When we are printing a large order the printer will start printing what is supposed to be purple will come out blue and pink will come out a dull red
  • 600 Answers
Try cleaning the heads using the cleaning utiltity on its maintendnce tab, if that doesnt do it, you might have installed non-original laser toner, kindly check also the color settings on what software you use. try also adjusting your screen resolution and color scheme. it could be that what appears on your screen is really not it seems.
Posted on Jun 02, 2010
How do I print in grayscale.I do not get the option in print menu
With respect to color usage during greyscale printing: Unfortunately, with many of the newer inkjet printer models & printer drivers, printing in greyscale actually consumes more color ink than normal draft printing. If you wish to save on color ink, it is suggested to do one of the following as available in your specific printer driver/software:
    -Print in Normal - Draft mode (or super draft if available), plain paper.
    -Print in Black & White mode only* - Draft mode on plain paper (typically this is the best way to save on ink/printing costs).
    -For internet page printing, print using CleanPrint (3rd party software for printing most internet-based content from all major internet browsers. NOTE: not affiliated with Inkjet411): http://www.formatdynamics.com/cleanprint-4-0/
    -Keep printer on at all times; power up cycles typically consume large amounts of ink (per Consumer Reports, Aug 2013 issue).
    * Most printer models will still consume a small percentage of color ink due to normal ink/printer maintenance, such as between job 'spitting'. The purpose is to ensure the printhead is maintained to avoid clogging.
    Regarding HP 74, 75, 74XL or 75XL repurchase or ink cartridge refilling, if you unable to find a retail / refill store close to you and you are trying to cut ink costs, may we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available to US residents only).
    Here is a link to retail ink cartridge refill stores:
    http://inkjet411.com/?page_id=483
    For any additional questions please contact us directly: Inkjet411help@gmail.com
    -Thank you
    Inkjet411 Team Member
Nov 16, 2014 | HP Photosmart C4580 All-in-One InkJet...
Mfc 5860 red printing green - already checked print levels. all are fine.
1. Confirm that the colors are incorrect by printing a Print Quality Check Sheet
a. Press INK.
b. Press the UP OR DOWN ARROW key to select Test Print.
c. Press OK.
d. Use the UP OR DOWN ARROW key to select Print Quality.
e. Press OK.
f. Press COLOR START
The machine will generate the Print Quality Check Sheet.
2. The LCD will ask "IS QUALITY OK? 1. YES 2. NO"
a. Press STOP/EXIT to return to the "Date and Time" display.
3. Evaluate the Print Quality Check Sheet.
On the Print Quality Check Sheet each of the four colors is represented by a slanted square pattern made up of 96 individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
NOTE: Cyan is the light blue color and magenta is the pinkish color.
a. If the colors on the Print Quality Check Sheet do not match the sequence listed above then the ink cartridges are most likely installed in the wrong order. Continue to STEP 4 to resolve this.
4. Open the Ink Refill cover.
5. Open the cartridge covers of the colors that do not appear in the correct order.
6. Remove the cartridges and reinstall them in the correct slots. On Brother Genuine Cartridges the color of the label will match the color of the cartridge cover.
7. Run a "Setup Purge". A Setup Purge is necessary to replace the ink in the ink supply tubes with the correct color. One or more of the ink cartridges may run empty during this process. If they do, replace the empty cartridge with a Brother Genuine Ink Cartridge before continuing the process.
a. Press MENU - BLACK START - MENU. The LCD will display Maintenance.
b. Press 7-6, The LCD will display CLEANING ALL
c. Press 6, the LCD will display eINIT__P ALL
d. Press the RIGHT ARROW key until one of the colors that was installed incorrectly is displayed. i.e. eINIT__P CYAN.
e. Press the BLACK START Key.
  • After the machine completes the Setup Purge it will return to the Standby Display.
8. Print another Print Quality Check Sheet
a. Press INK.
c. Press OK.
e. Press OK.
9. The machine will generate another Print Quality Check Sheet.
a. If all four colors printed correctly the issue is resolved.
b. If one or more of the colors are still not printing in the correct order repeat STEPS 4 - 8.
Feb 17, 2011 | Brother MFC-5860CN InkJet Printer
My canon pixma mp620 won't print black ink but other colors print ok.
Does printer have 2 black cartridges, 1 large 1 small? if so, the small black one and colors only takes care of the color print jobs and the large black one, the main black and white jobs. Make sure you don't have an empty large black cartridge.
Aug 15, 2010 | Canon PIXMA MP620 All-In-One InkJet...
QUESTION FOR DON_FARR
whenever you print greyscale what actually happen is that the printer mixes the red, blue and yellow to give the output in gray scale. See if you mix red, blue and yellow ink in the right proportion it gives you very close to black. just try to print your greyscale with your black ink finished you will still get the same print quality as when the black has ink in it. Or find a way seal the nuzzle of the black in and print your greyscale. check what results.
Dec 12, 2009 | Canon PIXMA MP610 InkJet Printer
My epson c45 not printing the exact colors that is
I suppose that you have cleaned the heads to eliminate any clogging. In that case the Printer cartridges were probably refilled in the wrong order. Try using a new one and post again if it's the same.
Nov 02, 2009 | Epson Stylus C46 InkJet Printer
Printing is off center on the HP 6540. The image or page being printed is cut off on the right margin and on the bottem of the page.
ok, most likely your printer cartridges are off. In order to fix this, you can use windows to align them. Click start > Control Panel > Printers and Faxes, and right click the printer thats giving you trouble. Then go to properties. Next, go to the services tab, and click align the cartridges, and continue from there.
Sep 01, 2009 | HP DeskJet 6540 InkJet Printer
Epson 9800 wont print large images
make sure that the printer is not managing color by selecting "off (no color adjustment)" in the Printer Color Management option of the printer settings.
Could be a head clog, could be ink starvation, could be head overheating...
How old is it ... ?
Fame !
Jun 25, 2009 | Epson Stylus Pro 9800 InkJet Printer
Can I set default printing to black and white for color laser printer?
Yes. Any printer's default options can be set as desired. Open the printer's properties (Start/Control Panel/Printers/right click the printer and left click Properties), and change the setting as you wish, then click OK. Those settings should be used each time you use the print command, unless you change the settings for that particular print job.
Hope this helps, and please rate my advice, good OR bad.
Feb 05, 2008 | Office Equipment & Supplies
My canon i860 is printing funny stripes on all colored docs
I am having the same problem. Does anyone know the solution to this one?
Oct 21, 2007 | Canon i860 InkJet Photo Printer
Dell 1320c Laser Printer Logo
375 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
