Question about Toshiba Satellite A105 Notebook
Display splits into multi-color lines
I have a A105-S4014, if I connect an external display all is fine. I'm wondering if a connector to the laptop display is loose after dropping computer while in it's carrying bag.
DD
  • 479 Answers
There might be two resons behind splitting:
1. The display panel cable is faulty or loose.
2. Display is faulty.
As you are saying that external display is working fine means there is no issue in system board. The display is very sensitive and no matter it is in the case.
The issue here seems with the display panle itself.
Thanks
Posted on Jun 02, 2010
Display divided into 3 parts
LCD screen cracked, and Three even strips going across? Doubtful. Haven't seen it but I always have my mind open.
Three strips that are irregularly shaped? Look like glass that has cracked?
'Jagged edges'?
LCD screen is broken.
Three even strips indicates to me, that there may be a problem with the Video Cable. Then the screen Inverter is next in the diagnoses.
My money is on the Video Cable.
ALL power removed, Anti-Static Precautions FOLLOWED, I would check out the graphics chipset first.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the laptop.
Left rear side. This is an example of a VGA Cable, and VGA connector. (VGA port on a laptop ),
http://en.wikipedia.org/wiki/VGA_connector
(Color of connector does Not matter. It is generally Blue, though)
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
There are at least 3 display options available;
1) Laptop internal monitor ONLY
2) Laptop internal monitor AND external VGA monitor
3) External VGA monitor ONLY
Press, and hold down on the Fn key, and at the same time tap once on the F5 key. (The F5 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F5 key.
Is the display on the external VGA monitor, the same as the internal monitor of the laptop?
Problem is the graphics chipset.
Display is fine on the external VGA monitor?
Problem is the Video Cable, screen Inverter, or LCD screen.
Video Cable:
A) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-14.jpg
Switch Cover removed, Keyboard removed. Shows you where the Video Cable plugs into the motherboard.
B) http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/big/Toshiba-Satellite-A105-21.jpg
Palm Rest Cover you can see the white rectangular connector, for the motherboard side of the Video Cable, at the top left.
It's above the black cable, and near the screw hole.
The Video Cable leads from the motherboard, up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter, and back of the LCD screen.
http://www.ebay.com/itm/Toshiba-Satellite-A105-6017B0050801-LCD-Video-Cable-Genuine-OEM-Laptop-TESTED-/290754851160?forcev4exp=true&forceRpt=true
In the photo, (You can hover your mouse cursor on it to enlarge), the right side connector plugs into the back of the LCD screen.
The black connector to the far left connects to the motherboard.
The small white connector at the top with the Red, Green, Black, etc wires, connects to the screen Inverter.
(The small Black cable, that comes out from the black motherboard connector, is a Ground wire )
Due to the close proximity of the Video Cable to the left Hinge, it can be pulled on from just normal opening, and closing of the laptop over time.
This means the Video Cable connection on the motherboard side could be loose, or the LCD screen side, or both.
The diagnoses is to PHYSICALLY check BOTH connections. A loose connection at the motherboard, or at the back of the LCD screen could be so small in distance, that you will not see it with the human eye.
Could also result in damage to the Video Cable.
View the Video Cable with the Switch Cover removed, and see if there are any obvious signs of damage to the sheath of the cable.
If there is there could be damage to the tiny wires inside the Video Cable. (Stretched/Broken)
Use a multimeter set to OHMs, to check all wires inside the Video Cable for continuity, or have a 'Mom and Pop' computer store check it for a few bucks, or replace the Video Cable.
Video cable connections are tight? Video cable continuity check checks out OK?
Screen Inverter.
The test for a screen Inverter is to use a sensitive multimeter.
Read fairly expensive.
http://www.fonerbooks.com/test.htm
Not having access to a sensitive multimeter that you can use, means just replacing the screen Inverter. Seems like 'part changing', and it is, but you have to work with what you've got.
http://www.sparepartswarehouse.com/Toshiba,Satellite,A105,Laptop,Inverters.aspx
Find THE model number for your laptop, and the correct screen Inverter. A screen Inverter, and an LCD screen are a MATCHED unit.
Screen Inverter is checked out to be OK, or replaced, and symptoms are still the same, the problem is the LCD screen.
Remember, the first part of the diagnoses was to see if the divided parts were EVEN going across, or jagged and irregularly shaped.
Jagged in shape, and not even strips going across, means cracks in the LCD screen.
Replace.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-replace-LCD-screen-1.htm
[ Main article for A and B links above;
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm ]
For additional questions please post in a Comment
Regards,
joecoolvette
Oct 22, 2012 | Toshiba Sattelite A105-S2051 Notebook
Screen will not load just white lines
Does external display work fine? If you have not checked, connect an external display like desktop monitor or a LED TV which has VGA connector to your laptop's vga port. You may have to use some fn keys combination to switch from laptop display to external. If external display works fine then check the display cable connecting laptop motherboard to laptop display. And also check laptop LCD/LED screen. You may have to try another with another screen in such scenario.
Sep 17, 2012 | Pavilion g7-1219wm Notebook PC
Dvdrom can't read
may need to be replaced does it spinup with disk in?
Jul 04, 2011 | Toshiba Satellite A105-S4014: Satellite...
Toshiba Satellite A105-S4014 15.4" Notebook with
If the drivers aren't loaded, it won't work properly.
Please check your model number as I cannot find it on Toshiba's database.
Try www.computers.toshiba-europe.com and let Toshiba detect your model.
Toshibe supports most models.
Nov 17, 2010 | Toshiba Satellite A105-S4014 Notebook PC
Can we connect 2 ecternal monitors to Toshiba A600 laptop
I am not sure about two external monitors but you can connect one editional monitor / HDTV with your computer. you just need to connect a VGA/HDMI cable to external dispaly and then press following keys together.
Fn, F4
There would be three options after that
1. display on computer screen only
2. display on external screen only
3. display on both.
You can select third option and it will work fine.
May 18, 2010 | Toshiba PortegeA600-S2201 Notebook
I need to know how to adjust the screen brightness on my toshiba satellite A105-S4014 laptop. There is no option to adjust it in the control panel, and the keyboard command, Fn + F6 dosen't have any...
For vista windows do these easy steps: 1) Start 2) Controll panel. " on right " 3) Personalization. " You should have it " 4) On the left top of this screen you might press on " Connect to a projector or other external display " 5) ajust the britness and any other options as you like. Tell me if that was helpful.
Dec 09, 2009 | Compaq NC8000 Notebook
Screen has different color lines through it (acer aspire 9300) the picture of what ever web site i"m on turns into different color lines
Connect external monitor and check if the video is good that mean the vedio card or the driver is corrupt...try reinstalling the driver if issue persistes then video card is fautly.
Regards
Priti
Aug 24, 2009 | Acer Aspire 9300 Notebook
Replace monitor?
how to take the monitor off the laptop and replace
Aug 19, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite a105-s4014 wont turn on
Dead could be a shorted MOSFET in the CPU line which is common for the age. Need to verify Voltage at Jack and the I/O's the BIOS chip..
Feb 02, 2008 | Toshiba Satellite A105-S4014 Notebook PC
Moniter problem
the LCD screen is damaged.
hope this helps
Jan 08, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
347 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
