Question about Toshiba 51H93 51" Rear Projection HDTV
Horizontal output transistor failure
The horizontal output transistor on my 51H93 TV has shorted several times, taking out the circuit fuse.
What could be causing this?
  • JHD923 Apr 17, 2008
    Where could I obtain one of these mods?
  • JHD923 Apr 23, 2008
    Thanks, scott201201. Do you know of a third-party that would have information on these mods? I tried contacting Toshiba several times at several numbers, but they couldn't help me.
    Scholar:
  • 170 Answers
Check b+ comming from p/s. also check for blue flat caps in line with h-output circuit. if blown out the side. remove them from circuit. also might have a HVT goin bad. I believe this is also the model that might have a mod for h-out running too hott that requires adding a resister in the h-drive circuit. also try a heavier duty h-output.
Posted on Apr 09, 2008
  • Scott Henderson
    Scott Henderson Apr 17, 2008
    i have only had to do one of them, but you can contact toshiba and talk to them, let them know that this is your problem and their tech know about it, and you would like the kit.
    or you can replace it with another h-output useing heat sync compound. but i would say use a stronger h-output.
    the right fix is the kit and i would ask to speak with tech support.
    if you can't get to them then ask for parts dept and have them look up your part number.
    good luck.
  • Scott Henderson
    Scott Henderson Apr 23, 2008
    http://www.tritronicsinc.com
    i think they have a kit for it, but to get the correct part number you may have to ask them. if they dont know get with me
HOW TO FIXS HITACHI TV WONT COME ON RED LIGHT FLASHING PROJECTION TVI
model number?little more info...first thing check for short in power and
horizontal output transistor-common problem.also bad connection
cap in horizontal output circuit can cause blown fuse
May 28, 2014 | Hitachi Televison & Video
My 1998 hitatci tv keeps blowing fuse whats wroung
The TV has two power supplies, low and high voltage. Most likely the high voltage transistor (called a Horizontal Output Transistor or HOT) is shorted due to a malfunctioning high voltage transformer (the biggest piece on the board with the large red wire coming from it. If the low voltage is bad most likely the diode pack (full wave rectifier) or the voltage regulator chip.
Remember fuses are to keep the unit from catching fire by opening up when a short circuit draws too much current. If you cannot replace the cause of the current draw, it's time to buy a new TV.
Feb 27, 2014 | Televison & Video
Sharp tv primo 21`inch turn on red light only
check your horizontal transistor maybe it's shorted replace horizontal transistor or maybe the fusible fuses are open check for open resistors at the horizontal section of the circuit.
Dec 22, 2010 | Sharp Televison & Video
SONY KP-61V90 tv will not power on, red light in front,
Its 2 times blink error code that shows +B volt supply (+135 volts) is shorted, most probably horizontal output transistor is shorted, replace it.
If you are good in soldering parts in circuit board then take out horizontal transistor, check it, found shorted then replace it with same number.
Horizontal output Transistor Q502 number is 2SD2578 and available in Part Store for $10
Let me know for further query, if any.
Thanks.
Nov 18, 2009 | Sony Televison & Video
Toshiba 51H93 .
check for cracks in the driver circuit, also i believe this maybe on of the models that had a kit that helped from driving the h-output to hard causing it to get hotter then normal.
Apr 11, 2008 | Toshiba 51H93 51" Rear Projection HDTV
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
RCA Guide Plus Gold Gemstar
The set tries 3 times to come on (3 blinks) if there a problem such as a short, it will cycle without turning on. Unfortunately your set is notorious for having bad flyback transformers. Most likely the horizontal output transistor is shorted as well. Common causes for your symptom are: LL05 (horiz out transformer) RCA part# 257805; TL 02 ( horiz output transistor) 2SC5148; and open connections on the printed circuit board at LL 04 and L14401 (coils) all of which can cause the horizontal output transistor to be shorted.
0
Nov 25, 2007 | RCA F32450 32" TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
KV-32XBR15
Yes, you should check other parts. The horizontal output transistor is more than likely shorted. Also the flyback could have gone bad. Some SONYs have problems with the horizontal driver transformer which is connected to the base circuit of the horizontal output transistor. If this little transformer has a loose solder connection, it will take out the horizontal output transistor. This may give you some insight as to where to look for your problem. Stargazer
Jun 11, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-32HS510, worked perfect, turned on the next day and all I gat is flashing red light.
Your tv does not need a reset,what happened something went bad inside the set and it needs to be replaced,if you are familiar with tv service you can start by checking the horizontal output transistor for a short,if he went bad it likely made the fuse or safety resistor open.If you are not too familiar with tv service be safe and call for assistance froma servicer.If you decide to go in looking for problems make sure the set is not plug in.Let Us know how it goes or if you need more information.
Oct 19, 2006 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Toshiba 51H93 51" Rear Projection HDTV Logo
147 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
