Question about Power Center Jumpstart 11-411
My Motortrend Jumpstart will not charge. I have
My Motortrend Jumpstart will not charge. I have been charging my unit for over two days,however, it has not charged. the compressor will not work so I know the unit is not charging. What might be the problem?
2 Suggested Answers
  • 31 Answers
SOURCE: will not jumpstart
To recharge this unit at home use the AC charging adapter. Plug one end of the adapter into the AC/DC charger input port. Which is marked as number 7 on the image below. Then plug the other end of the adapter into a standard wall outlet. The charging port is located on the front of your power center and looks like the image below. If you did not get an AC charging adapter with your power center check the manual to see exactly what type you need. You will need to know the Voltage and AMPs of the adapter. Go to Radio Shack or an electronics store and purchase an adapter. It is very important that you make sure you get the right one. Your manual should tell you how many hours it takes to completely charge your power center.
Posted on Mar 14, 2009
Why does my new motor trend power house jump starter with air compressor not take a charge from the a.c. or d.c. charger?
Contact manufacturer. If still under warranty they should replace. Sounds like the internal battery is dead...there has to be a little "juice" left in the battery for the charger to have a complete circuit to charge...some of these units take 24 or more hours on an initial charge.
Hope this helps,Ron
Nov 30, 2014 | Power Center Jumpstart 11-411
How to recharge superex jumpstart/compressor
Plug in the cord with the switch off. If the battery is still good in the unit then it will take a full day to charge. If you charge it for a full day and you still have nothing the battery is bad. If this is a new unit, check to see if it is under warranty.
Sep 06, 2014 | Superex Canada Ltd Emergency Jumpstart...
How do you recharge a Motor Trend Jump starter and air compressor
Should have been a patch cord that connects directly to the unit and to 110 volt plug for charging the unit back up. There's a built in convertor that does the re-charge. Find that cord or purchase one from where you got the unit.
Jun 28, 2014 | Power Center Jumpstart 11-411
How do I recharge a Motor Trend jump starter
Get a recharge cord for the unit, plug it in and recharge.
Unit will not take a charge. Roger
do you have a multiy meter ? can you check to verify your adapter unit is providing power ? are you capable of taking your unit apart and locating the devices internal that make your unit function ?
If so contact me further for more info
best regards Falco
Oct 14, 2013 | RoadPro RPAT715 12-Volt Rechargeable Air...
Fuel leaking engine
Recall ID # 65689 - FUEL SYSTEM, GASOLINE:DELIVERY:FUEL PUMPminus.gifHide DetailsRecall Date:FEB 26, 2007Model Affected:1997 Pontiac SunfireSummary:CERTAIN DELPHI AFTERMARKET FUEL PUMP MODULES / MODULE RESERVOIR ASSEMBLIES (MRA) THAT WERE SOLD FOR USE ON THE ABOVE LISTED VEHICLES. DURING PRODUCTION THE MRAS VENT AND FUEL RETURN TUBES WERE REVERSED. THIS CONDITION CAN RESULT IN THE VEHICLE NOT RUNNING CORRECTLY (IDLE ROUGH AND/OR STALL) DUE TO AN OVERLY RICH FUEL BLEND OR THE VEHICLE'S EVAPORATIVE EMISSION CARBON CANISTER MAY LEAK FUEL.Consequences:A STALLED VEHICLE CAN INCREASE THE RISK OF A VEHICLE CRASH. A FUEL LEAK CAN RESULT IN A FIRE.Remedy:DELPHI WILL NOTIFY OWNERS AND REPLACE THE DEFECTIVE MRAS FREE OF CHARGE. THE RECALL BEGAN ON MARCH 20, 2007. OWNERS CAN CONTACT DELPHI AT 1-877-335-7443.Potential Units Affected:3124Notes:DELPHIhttp://www.motortrend.com/cars/1997/pontiac/sunfire/recalls/
Read more: http://www.motortrend.com/cars/1997/pontiac/sunfire/recalls/#ixzz28amgeK4X
Oct 07, 2012 | 1997 Pontiac Sunfire
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
Hello. I have a duralast jumpstart kit. After
Hi, usually after you drain the unit down it will take up to 4 hours for it to charge up 100%. but do not leave it on the charger all the time when not in use because this decreases battery life.
May 23, 2010 | RoadPro Road Pro 12 Volt Dc Portable...
Will not jumpstart
Mar 13, 2009 | Power Center Jumpstart 11-411
Power Center Jumpstart 11-411 Logo
161 people viewed this question
Top TREND Vehicle Parts & Accessories Experts
Lawrence Oravetz
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a TREND Vehicle Part and Accessory Expert? Answer questions, earn points and help others
