Question about Dynex DX-LCD32-09 LCD TV
Dynex 32" LCD - bottom 2/3 of screen is black w/ colored lines
Dynex 32" LCD (DX-LCD32-09) - bottom 2/3 of screen is black w/ colored lines. This is what it looks like (see link -- not my actual TV, but it's a photo I found when Googling this problem). Any suggestions?
http://www.dumpt.com/img/viewer.php?file=x7akai1zbwvhpxrkxco7.jpg
  • philderosier Jun 12, 2010
    Unfortunately not. Mine is out of warranty as well (bought it about 18 months ago), so I took it to a service guy, who told me that the LCD screen itself is bad. To replace it would cost more than the whole TV. I hope you have better luck. I've read other places that sometimes the problem can be caused by a loose connection or if either the "t-con board" or "DSP board" is bad (those can be purchased for less than $100 if you look around). I hope you have better luck. I really regret trying to save money buying this TV. On Best Buy's website, if you look under the reviews, you'll see several people describing this same problem - and always just outside the warranty. Next time I'm sticking with a reputable brand (Best Buy's response is "buy the extended service plan," but I find that response unacceptable). My other TV is a Panasonic, which I've had almost 4 years and is our main TV, and it's been great.
    New Friend:
I have the EXACT problem as well. I found that if you take the back off and lightly spray it with am air compressor or a can of air spray for electronics, it tends to work again. I sprayed about 2 years ago and it is just now doing it again.
Posted on Feb 18, 2015
My screen looks EXACTLY like that! I called Dynex and they told me my warranty is out and they cant fix it. I have only had this TV a bit over a year. Did you get a resolution??
Posted on Jun 12, 2010
  • bates1919 Dec 05, 2010
    That's just like mine too. Manufactured October 2008. Guess they aren't looking for or expecting repeat customers.
How to fix a dynex 32 inch flat screen distorted screen,it looks like it is cracked but its not!?
Check and replace its T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Nov 07, 2016 | Dynex Televison & Video
Why my screen says please wait then goes black
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 05, 2014 | Dynex DX-LCD32-09 LCD TV
I was watching my Dynex 32 LCD when picture went out and I had rainbow verical lines going from top to bottom?
did you ever find out why your T.V was doing that? the reason I ask is because mine is doing the same thing rainbow colors
Oct 15, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Cannot get full screen picture
Full screen resolution depends on the source signal that you feed to your LCD TV. Most often, the signal come in 16:9 screen size, which sometimes show big black portion on both top and bottom of screen. To maximizes screen display, you can adjust the screen size of your LCD TV through remote control, this features are available in most LCD TV. you will have the option to choose Full Screen Mode, 16:9 screen resolution or many others to choose from (most case about 3 to 4 screen size.
Jul 03, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Do all flat screens use different bases
Flatscreens made by the same manufacturer and of similar screen size may share the type of base but mostly they are different.
For example a 27" Sony may have the same base as a 32"Sony, but it will be different than a 46" Sony.
The specifications and the OWNER'S MANUAL for your tv is found at the following link:
http://www.dynexproducts.com/products/televisions/DX-L42-10A.html?supportTab=open
The direct link to your OWNER'S MANUAL is here:
http://www.dynexproducts.com/cms/documents/DX-L37-L42-10A_08-1837_MAN_V1_ENG%20Final%20lr.pdf
It looks like DYNEX uses the same base for their 37" and their 42" tv's but that's not guaranteed.
Good luck and comment back if this was helpful.
Jan 30, 2011 | Dynex DX-L42-10A 42 in. LCD TV
Not a full screen
Change the aspect ratio setting in the menu options
Apr 25, 2010 | Dynex DX-L32-10A 32" LCD HDTV
The TV (Dynex DX-LCD32) will not come on. The
I have a DX LVD33 power light is red and no picture or sound screen is black. Please advise.
Dec 25, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
I have a DYNEX 32 lcd tv DX-LCD32-09 that was manufactured in 02/09. I have audio but the picture is only vertical colored lines. It was given as a gift and I cant get the receipt or it would be under...
The vertical lines from the top of the screen all the way to the bottom of the screen is the sign of the bad LCD panel, you need to find the receipt.
Nov 05, 2009 | Televison & Video
Looking for a replacement LCD for the Dynex DX-LSD42HD-9 (Wii Remote Crash). ( has cool Circular color bar with vertical lines now) John
open the set up and get the generic number of the panel written on a white sticker on the panel itself then do a google search yoou might get lucky
Sep 28, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Dynex DX-LCD32-09 LCD TV Logo
899 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
