Question about Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not filling up with water from the start
  • dickstrong Jun 03, 2010
    The issue was actually, water in the pan below the unit causing the float switch to be engaged and not allowing water to enter the dishwasher.. Solution: Shut the breaker off, take off the front cover of the unit. Then take off the kick plate cover (2 screws) below. You will then see the pan on the left side (with a flash light). Use a Turkey baster ~ to suction the excess water from the pan below. Replace the covers that you removed, reset breaker and start the dishwasher
  • dickstrong Jun 16, 2010
    Check where the door of the unit closes and seals. if there are water stains, a possibility is that the gasket maybe faulty or that the unit is not level.. Or as you mentioned the a faulty inlet valve. Another thought is the spinning sprayer in the middle of the unit ~ if that is restricted at all or not spinning freely. the sprayer could be spraying against the gasket protecting the seal and its giving way.. I hope that this helps
This is exactly what my SHU43 is doing, and yes, once I siphon the water out of the pan, it runs normally. However, I have to do this about once a week and it is getting worse. So what is causing this water to build up pan?
Posted on Jun 16, 2010
  • mrdenisn Jun 16, 2010
    Sorry, I did not intend to offer a "solution" but to gain clarity about my issue. How can a restriction in the water supply cause too much water to be in the pan? I am getting too much water, not too little. Can the inlet valve slowly "leak" causing water to trickle in at all times?
  • 1,531 Answers
There may be a restriction or bent water supply line.if there is no physical problems with the line then you may need to replace the water fill valve.make sure the main water supply is turned on
Posted on Jun 03, 2010
  • seth adams Jun 16, 2010
    there can be a leak with the water fill valve.make sure to check the wiring to the fill valve and make sure there is no shorted wires causing current to be applied to the fill valve. you may need to replace the fill valve
Boscsh shu3322uc dishwasher won't fill. If I put
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 09, 2011 | Bosch SHU3306UC Built-in Dishwasher
Switch dishwasher on and starts up ok but when it comes to pumping water in it stops and does not do anything else.
Hello
Investigate these five areas if your dishwasher won't fill with water:
As water is filling your dishwasher, a float rises along with it. When the float reaches a predetermined level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Check your float assembly. Replace it if you need to.
The water that fills your dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with your dishwasher's filling ability.
Your dishwasher may not be filling with water simply because the water valve's filter screens are dirty and debris-filled. Gain access to your water inlet valve and try cleaning it out. This might be enough to solve the problem. You can learn how to access your water inlet valve in the replace a dishwasher water inlet valve section.
Alternatively, your water inlet valve could be defective altogether. That could be the reason your dishwasher is not filling. Test it for continuity. If it is not functioning as it should, replace it.
Your dishwasher's drain valve is regulated by a drain solenoid. If the solenoid is malfunctioning, it may not allow the drain valve to funtion properly, which in turn could be the reason your dishwasher is not filling with water. Investigate your drain valve and test the solenoid. If the solenoid is faulty, replace it.
Aug 22, 2011 | Dishwashers
My dishwasher seems to start ok then the first light starts flashing and it do'es nothing just stays there any ideads what my problem is
Can you tell if it's filling with water. The first thing it does is fill with water (usually on a timed cycle) before the pump starts. If there's no water in the tub, it obviously won't wash dishes, since a dishwasher is nothing more than an enclosed pressure washer. If it does not fill with water, you may have a bad fill valve or the timer that turns the fill valve on may be defective. You DO have the water turned on, RIGHT?
Jun 11, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
I have a whirlpool dishwasher (gu2500xtpq6) wont fill up
water level should be approx 1/4--1/2 inch below the heating coil.. this is normal fill level
Apr 28, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Dishwasher does not fill with water when started. Problem began slowly with dishes not rinsing completely. Overfill float appears to work properly. Water fills pipe leading to fill solenoid but does n
I am almost certain that your problem is the fill solenoid.
If it does not work, there will be no water entering your machine.
I would either remove it and test it or just replace it at this point.
Tim
Apr 16, 2009 | Dishwashers
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
BOSCH dishwasher SHU5302UC12 water will not fill
was the safty tab on the inside of the units water receiver removed?
Jan 05, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Whirlpool dishwasher will not fill with water
turn the valves to the left if there the screw in type or parraell if the quick open type the first thing a dishwasher does when you start it is drain for a few minutes then stops then fills with hot water run the water as hot at the sink as you can before starting the washer there is a float in the tub that can shut the water valve off if its not seated on the safety switch after the drain at the start of cycles stops then you should hear the water valve open and start the fill let me know and we will go from there
Mar 27, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Water not coming into dishwasher
Pour a bucket of hot water into the dishwasher (be careful not to overfill) then turn the dishwasher on. You'll probably have to wait a couple of minutes before it will start up. If it starts spraying water around inside the dishwasher, you have a bad fill valve and everything else is working properly. A fill valve is cheap and easy to install. You shouldn't even need to pull the dishwasher to replace the valve.
Mar 03, 2008 | Zanussi 24 in. DE6965 Built-in Dishwasher
Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Nov 14, 2006 | GE 25 in. Nautilus GSC3400J Free-standing...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
353 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
