Question about Kenmore 75085 Air Conditioner
My unit dont turn on. it look like it is on, since the green light are on, but the unit dont cool neither make any noise
  • yvonnega Jun 02, 2010
    hi it is a 150000 btu unit kenmore model 580751515000
    the unit is dead, but whan i press the power button the display light turn on, like showing the temperature, mode (fan coling etc) it has a reset button at the endo of the power cord, i have press it but nothing. thanks for your help
    President:
  • 1,515 Answers
Hi, I looked up this unit, 5 to 8,000 b.t.u's about 1/2 of cooling, good unit. You say its not doing anything at all like maybe blowing just warm or room temperature air, or just a green light is on and its dead in the water? It didn't give me anything on stats for this unit, but you must have power to the unit. What I would do first, is to find the breaker that controls the plug that you run it on, turn it off for about 7 to 10 minute's, and reset breaker to see if there's a change. If you are a handyman or lady, you can try, since this is a newer model, try after pulling the plug, removing the front cover. Take the knobs off. Where the knob for the thermostat control is mounted, you should find some screws and a metal plate you can remove and this is where you will find your wiring control compartment. Look for any reset in the area, or possibly they may have a portion of this unit fused on the circuit board like they do on the larger circuit boards. Look for any signs of burned or blacked areas in the electrical area also. If not, we will have to go from there and take the steps to trouble shoot deeper into the system to find why you have power as the led light is on, but something has taken place. Keep me posted, and start at the main power supply like I asked first and we will go from there. Let me know what you find.
Sincerely,
Shastalaker7
Posted on Jun 02, 2010
  • Robert Horton
    Robert Horton Jun 03, 2010
    Hi, Thanks for getting back to me. Yes, the first model number that was listed showed it was a 5,000 to 8,000 btu unit, but doesn't matter. So, you do have a reset on the power cord itself. It has to be reset or you would not have any display at all, so this unit is off on a safety control switch, for example, a low pressure switch, high head pressure, which means the outdoor coil may be dirty. You can take a hose and wash it out to see if this changes anything. This happens a lot on all other units as dirt gets drawn into the coil causing high head pressures in the unit. These are cleaned during a service on a unit, but it is something you can try. I just want to give you some idea's you can check on your own as you are limited on what you can do with out the equipment. Since the compressor or fans are off, the system is locked out on a control and without being there to read the schematic to check the sequence of operation, makes it tough as there are no symtoms but a unit that's doing nothing but has power to run. It has to be off on one of those safety's to keep it from doing more damage to this unit. Wash that coil out and we can see if it is off on high head and may reset the switch that's in the system. This is all it takes is for one switch, either a normally open or closed set of contacts to malfuntion and shut it down. If this does not do it, you may have to call a tech to locate what has happened, as it would be almost impossible for me to walk you through the wiring diagram and locate which part has failed. It doesn't sound major which is good, or the reset would be tripping each time. I would call around and check prices. Normally it will be a 1-hr. minimum to come out and check it. If you do end up calling, ask if there is a travel charge, trip, or truck charge. You should be able to find someone that will include everything in a 1-hour charge. When I worked for other companies in the past, our service manager would give us 1 hour to trouble-shoot and find the problem on a residential unit. Just make sure they are a licensed contractor, and anything over 1 hour should be broken down in 1/4 hours. I wish you all the luck on this, and it would be great to be there. Try cleaning the condenser coil and that may take care of the problem, you will know.
    Sincerely,
    Shastalaker7
Bought this house with the Lowes Iris Radio thermostat. totally unable to get the cool to work took a lot of playing around to get heat. don't want to wifi it, help
you must tell the tstat if it controls a heatpump or straight cool unit. If you dont know provide model numbers of outdoor unit. If this is correct turn power off to indoor unit and combine the red green and yellow wires inside tstat and turn power on. If indoor AND OUTDOOR units run are you heating or cooling??? If all is running and it is heating turn power off and add the "O" to the bunch and turn power back on. NO NEED TO PUT FACE PLATE ON TSTAT. this is bypassing tstat for test purposes. If system now cools with indoor and outdoor units running you have a setup issue with the tstat. FIRST BE SURE TO TAKE A PIC OF THE WIRING. Follow up with me with outcome I'll help u further.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 13, 2018 | Heating & Cooling
I CHANGE THE BATTERY TO REMOTE CONTROL AN DONT WORK AN THE UNIT THE GREEN LIGHT IS BLINKING
This is an alert. Your unit has a self diagnostics. The blinking light indicates a malfunction. check or clean the air filters. Go to the outdoor unit or your breaker box and turn off the power. Wait about 5 mins then turn power back on. Turn your controls to cool and temp down. If this dont work then it needs service.Call a service technician.
Jun 04, 2015 | Heating & Cooling
Matercool thermostat wont turn on drain pump
Condensate pumps dont work with the thermostat . The pump has an internal float switch that kicks the pump on when the water reach a high level. If the pump failed for any reason the safety swicht will turn off the ac unit to prevent any water overflow.
Sep 07, 2017 | Mastercool Heating & Cooling
I have a bryant model 702b packaged unit with 5 wire thermostat wiring coming out of the unit. R Y B G and W. The thermostate in the house is 5 wire and goes to the old central unit and them has a 4 ire...
R-Red is power
Y-Yellow is cool
B-Blue is cool as well
G-Green is fan leg
W-White is usually heat Leg
If you have no indoor unit and this is a ac/gas or
electric outdoor unit try this.
R to R/Red to Red
G-G/Green to Green
Y-Y/Yellow to Yellow
W-W/White to White
-Dont Hook up Blue.
Turn power back on turn the fan to on,fan should run
Turn to Heating, heating should come on
Turn on Cooling,if cooling does not come on switch yellow with blue.
Jul 02, 2010 | Heating & Cooling
Have a KDF 60Wf 655 will not turn on. Green light comes on then red light with 7 blinks any suggestions? Took bulb out but the bulb light never lit and the bulb doesn't look blown.
Wether it looks blown or not replace it and dont put oil from your fingers on the bulb. Also clean the cooling fans for the bulb and projector (which may mean taking the back off and taking apart projector). Dirt in the projector fans can cause a fault not allowing for the unit to turn on. All the cooling work ins conjunction with a good bulb.
Apr 24, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
LG32lc7d unit. When it is cool and you turn unit
It sounds to me like there's a few bad capacitors on the main power supply board,take the back off and look around for any electrolytic capacitors that have puffed out tops.
If this helps please give a positive feedback
Nov 01, 2009 | LG 32LC7D Television
Fan on unit will not turn on in cooling mode
Check to see if the green thermostat wire is conneceted to the "G" terminals on the thermostat and on the furnace.
Apr 20, 2009 | Ruud Central System Air Conditioner
Light keeps flashing red,amber, green
If you turn off the printer and turn it back on, do you get any noises, ie motor noises, or does it instantly go to all lights flashing?
If you get no noises this usually indicates a board fault and you should look for a new printer.
Apr 07, 2008 | Brother HL 5140 Laser Printer
Kenmore 75085 Air Conditioner Logo
210 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
