Question about Keurig B60 Coffee Maker
When making a cup of coffee, half the water flows back thru the vent resulting in half a cup of coffee. I have de-scaled but that did not fix. Any suggestions?
When the water comes back through the vent, it usually means that the TOP needle may be plugged with coffee grounds.
Unplug the coffee maker.
Lift up on the silver handle, and look inside. You will see a silver needle (similar to the one in the bottom of the K-cup holder). With a round seal surrounding it.
Straighten out a paper clip and run the clip through the center of the needle, and rotate it, then pull the clip out.
Plug the unit back in, and wait until it is ready.
Remove the K-cup holder, and run only water through the unit, as if you are making a cup of coffee.
You will see some grounds in the coffee cup, if the needle was plugged with grounds.
If this doesn't fix it, call customer service, the unit may be bad.
Posted on Jun 06, 2010
I have the same problem- does anyone out there know how to fix this?
Posted on Jun 05, 2010
I also used mrfixitmi's solution and it worked well for me. After inserting the clip into all three holes in the needle, making sure to get as far up as I could (without applying much force), I then ran it through three cycles without a K-Cup and the first two cups had noticable amount of grounds in them. The third was clear. Works great now.
I also cleaned out the bottom neele too, just to be safe.
Posted on Jun 10, 2010
For my Keurig B70 model I followed the mrfixitmi solution but used a twist-tie (paper-wrapped) on my machine. The top needle holes looked large so I just twisted the otherwise flat paper around the twist-tie and cleaned the center and side holes. In any case it worked well and the grounds came out.
Posted on Jun 08, 2010
It does not do a full cup....I have gotten it to finish when starting over but now I cant get the water to run out at all...
With the coffee maker unplugged and an empty cup in place, I filled the reservoir with filtered water and with a short length of flexible plastic tubing I blew in to the small hole in the bottom of the reservoir. I did this 4 or 5 times sucking some water in to the tube to force it through the system. When I had finished there were a lot of grounds in the cup and the next time I used the coffee maker it worked perfectly.
Feb 17, 2011 | Keurig B30 Mini Coffee Maker
Brews about half a cup of coffee. i have tried the paper clip many times
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 25, 2010 | Keurig B100 Coffee Maker
My coffee maker has the words de scale in the corner or something like that. Also all the lights are not coming on except the one for the most amount of coffee and it just trickles down to not even half a...
Dec 25, 2010 | Keurig B60 Coffee Maker
Water flow is weak and slow during brew
bcvb
cbcb
cvbcbc
Dec 23, 2010 | Keurig B60 Coffee Maker
After many uses, the cups are starting to get much smaller. when you brew a normal size cup, it comes out at about half the size of what it was previously
Dec 22, 2010 | Keurig B70 Coffee Maker
Does not brew coffee consistencty, water does not always flow from res tank...even if water flows down from tank the machine will make the heat noise show brew ready and when u push the button it either...
Dec 22, 2010 | Keurig B60 Coffee Maker
I have a Keurig B66, the reservoir water gets heated but then comes back into the water reservoir from the top vent tube. The water coming back into the reservoir is very hot; almost no water goes into the...
Try this first....
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
When ever i try to fix a cup of coffee and put the coffee in and try to brew it it just trinkles out. so can you help with my problem?
Dec 21, 2010 | Keurig Elite B40 Coffee Maker
Water runs thru maker without k-cup inserted but once I put a k-cup into maker the water drips out only and does not fill up the cup but when i remove the k-cup the water continues to run thru it.
Dec 20, 2010 | Keurig B70 Coffee Maker
My keurig discharge of pressure every hour if i dont use it ???? i have to play with it for half hour to get the pressure back in??? is it a cheap coffee machine or what??? garbage next monday??
4234234244Sorry to read about your issue.
Dec 19, 2010 | Keurig B50 Coffee Maker
Keurig B60 Coffee Maker Logo
2,003 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
