Question about Memorex Audio Players & Recorders
The needle skips across every record I have , What could be the problem?
  • Memorex Master
  • 5,397 Answers
You need a new one, or the counterbalance weight (on the arm) is set wrong for the cartridge installed.
Posted on Jun 02, 2010
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
Needle skips across record
your tone arm needs rebalancing most likely
Mar 19, 2014 | Sony PS-LX250H Turntable
Marantz tt 530 turntable
The needle skipping is caused by (A) a worn stylus. (B) not enough pressure. Which is solved by adjusting the weight on the end of the arm. It can only really be solved by trial and error. You increase the weight slightly, then play the record. You keep doing this till the record stays in the grooves but doesn't make a rumble sound. If it starts to rumble reduce the weight.
Aug 20, 2013 | Audio Players & Recorders
Hello i have a pioneer pl-300 turntable. i bought it used and it's been working fine until today. now the needle skips ahead on the record. i am VERY inept with technical knowledge of turntables i just...
if its skipping ahead Almost like the needle is just gliding across the Record. It means your needle is bent, dirty or broken, Take it off and look at it closely.
May 30, 2011 | Pioneer Audio Players & Recorders
While playing A cd the sound intermittenly stops like A skip and sound comes back but player is never moved
If the CD is the problem it could be scratched or dirty, clean the CD with a CD Cleaner if need be. If the CD mechanism is the problem the sled assembly may not be moving smoothly or is hindered ( the sled mech moves the laser across the CD like a needle arm move the needle across a record), the laser lens may be dirty also. Use a CD lens cleaner to clean the lens if you can not manually clean it with some lens cleaner and a swab. If the sled mechnism is the problem the unit may need to be taken in for service.
Jun 27, 2010 | Durabrand CD Player with Cassette...
The stylus skips across the record, despite readjusting the tracking force and the anti-skate control. After repeated adjustments for too little and too much weight, nothing helps. Does the stylus need...
If your needle skips across the record, then there is only 1 thing wrong with it... it's broken, and needs to be replaced.
If after you've replaced the stylus, and problem persists, then you have something a little more serious... Tonearm damage. More than likely not, but just in case replace the stylus does not help.
- OPTiC
Master Tech
Digital Analog Therapy
Technics Repair : Technics Turntable Parts
Aug 25, 2009 | Audio Players & Recorders
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Turntable swingarm skips to last song
Most likely your stylus (needle) is bent, broken or missing. Check to see if it's there or not. If it's broken or damaged, you will need to replace it. Under the cartridge, you should see a small arm that has the actual diamond on the end of it. If the arm is there, but the diamond is missing off the end, the arm won't stay in the groove and will instead skip across the record to the middle.
Mar 01, 2009 | Sony PS-LX250H Turntable
Sl-dd33 turntable
If your needle just started to skip across the LP, then that means your stylus is damaged/worn and needs to be replaced. It's very hard to see the diamond tip on the stylus, and it might not even be there at all. So checking it might not yield any results. This is what happens when the needle is worn. It will skip across the record.
- OPTiC
Turntable Technician
www.1200s.com
Aug 27, 2008 | Audio Players & Recorders
Fisher price 1978 record player
The Fisher Price record player has a device that prevented kids from pressing the needle down and sctratching the record. If you look at the cartridge where the needle is inserted, you will see that it floats up and down. The problem is that this keeps the needle from having enough pressure to play the record. Pennies just make the cartridge recede further into the arm. If you wedge something above the cartridge, the needle won't float and the it will play your records. I've had four of these and none of them worked until I figured this out.
Aug 02, 2008 | Audio Players & Recorders
146 people viewed this question
Top Memorex Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
