Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite Model 75546 bottom freezing up
I have a Kenmore Elite Model 75546 bottom freezer compartment with a problem in developing a build of ice in the bottom under the freezer drawer. I can chip away all of the ice but there appears to be water dripping from somewhere and freezing in the bottom. I can also see some ice drips on the back wall. Once the bottom is full I get a glacier than moves to the front and thaws and spills water out on the floor. Is there an easy fix or time to call a repairman?
lenwest
  • 150 Answers
SOURCE: Have the Kenmore Elite commercial refrigerator,
Try a sponge using gloves.Add hot water and continue with the sponge.
Posted on Feb 21, 2009
Maytag317
  • 1136 Answers
SOURCE: dripping water from freezer compartment into refrigerator compartment
Hi, Could I get the model #? The defrost drain is plugged and I can get you through this with the #
Some newer models need an after market drain heat strip added.
Vic
Posted on May 29, 2009
SOURCE: Water from freezer dripping into fridge freezing and accumulating
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Posted on Jul 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite model 106.54606300 side by side
It appears your defrost timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
We have a Kenmore Elite side by side refrigerator, model no. 53209, purchased in 2003. Recently the drain hole/hose to the drip pan beneath the freezer compartment has been freezing up, apparently during...
Good day,
It's become a common problem on newer machines with less frequent defrost cycles and for a shorter period of time.
The following clip, as you scroll down will see the most exotic procedure. You may not have to go that far.
Using a length of #14 bare copper wire, and wrapping it around the heater and inserting it into the drain hole will usually work. You will need to remove the heater to perform this process properly, and I prefer to wrap the copper close together, each wrap touching the last one. Your call.
kitchenaid-top-mount-refrigerators/" spwrap?>kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Your machine is a product of Whirlpool which makes many brands, all of them with the same basic system.
Oct 19, 2010 | Kenmore Refrigerators
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Control pad reads ER IF
er if means the ice fan is not running. it blows freezing air into the ice maker compartment from the freezer. unplug the refer for 24. these are susceptible to frost or ice forming in the blade of the fan and prevents it from spinning. unplugging it will let it thaw. ice is a big problem with this model.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge freezing
a defrost problem, is gonna cause excessive ice build up in hte frezzer lower compartment. for somereaon the hdefrost heater was not energized. most common reason is a bad defrost thermostat, clipped on one of hte evaporator coils has gone bad,
Mar 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
60 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
